Backing sheet drawing order (how to send to back)
Hi Everyone,
I would like to ask if anybody has met this problem and has solved it.
Situation:
    I am not included in Draw Admin of the project, but I need to create a customized backing sheet. I copied existing backing sheets and modified using command line. I have also created a macro that will fill up drawing information to attributes and change the BSRF automatically.
Problem:
    when the BSRF is updated to the BACK that I have created the VIEW disappears and seems to be behind the backing sheet.
Question:
    Is there an  attribute I need to set for the BACK element to control its view order to be behind the View/drawing?
Cheers,
Edgar
