at Hub server when I Run the daemon after one or two minutes the daemon is closed !!!!
I DICE check all the Hub databases and Transaction DB no errors!!
please help help me how can I solve this problem, it's so urgent.
thanks
version of global?
windows server?
What is your experience with PDMS?
Did Aveva helped you set it up or did you hack it yourself?
My experience with Global is that it normally works OK (ie if IT does not change network/firewall settings on you), daemon does not crash often. But when it does not work, it is a pain to fix. From your post I can not tell how much pain this could be.
Nothing is urgent, you can always offline transfer data between hub and satellites. So without global life still go on, just more work for admin. And I hope you are getting paid by the hour :-)
Hi, What is the reason for the below error, Daemon Batch process is getting failed frequently?
"forrtl: error (200): program aborting due to control-C event"
