I have a database at one of the satellites that has fatal errors. When I try to pull it back to the HUB to reconfigure it, it finishes with a Complete 0. The messages indicate that it was able to succeed with Primary location recovered. However, when I hit Modify in admin on that db it still shows to be primary at the satellite. If I can't pull it back to reconfigure it, what are my options?
It would say in failure messages that the file was in use and that the satellite location which could not be reached. None of these messages reflected the situation. I opened a ticket with Aveva and we tried to do a synchronise to push the secondary file out to the satellite and it failed with update not allowed. I ended up manually copying the non currupt db from the HUB to the satellite.
