I am at Hub and one of our db allocated to 2 satellites (primary in one of them) is throwing FATAL error. It should be reconfigured.
1. Where should I have to do the reconfiguratiion...HUB or Satellite?
2. Is the reconfiguration procedure same?
HI
CAn we reconfigure database from foreign database ?
Because I don't have password of user to access foreign database so I can not include foreign database ?
regard
Be careful!! when reconfiguring DB's on a Global project, it's not the same as a standalone, after the reconfiguration Global will NOT transfer the reconfigured DB. You must stop the communication before reconfigure, and after copy the DB(s) manually, otherwise you'll get problems.
