Global Module Closing a Global Project
  • Replies 4 replies
  • Views 25 views
m_pdms
m_pdms over 11 years ago
  • m_pdms
    Hi,
    I am closing a global project.... and i am at HUB
    can you please guide what are the steps to be followed or cautions to be taken.....
    i am putting the steps i know:
    1) make all the DB primary at HUB
    2) De allocate the DB from satellite....
    3) Change the Satellite Transcation Db  primary to HUB
    anything else....
    appreciate your suggestions...
    best regards
    m_pdms
    Orlando de Oliveira Amaral dos Santos over 9 years ago
    I think you have everything covered, how was the outcome of your closing?
  • m_pdms
    m_pdms over 9 years ago
    hi..,
    it went very well...and closed the project successfully...
    just a small correction from my first post is:
    no need to change the Transaction DB ownership....when the satellite location is deleted automatically the ownership changes to Hub....and before making any DB primary at Hub it is good to check whether the Updates were successfully between the locations and has to compare the DB Size / Pages for both locations and should ensure that data is updated till date.
    Regards,
    m_pdms
    That is good to know man, thanks for sharing!
    Cheers,
    Orlando
