Global Module Read Only DB
  • Replies 17 replies
  • Views 65 views
Read Only DB
Manuela Rodriguez
Manuela Rodriguez over 9 years ago
  • m_pdms
    m_pdms over 9 years ago
    ok kool...
    if the required ports are opened.
    ensure that the port no's value is changed in the files ADMINDWCF.exe.config and globalwcfclient.config under the folder globalserver
    for ex: if you are using port 8010 in the below line change the value to 8010 by default it is 8000
  • Manuela Rodriguez
    I will check ! thank you for your reply :)
  • Manuela Rodriguez
    Hi m_pdms
    Not solved... I will ask at IT to check... :(
    thank you for your help
  • Manuela Rodriguez
    Hi m_pdms
    again thank you for your help!
    I will check again your setup on AdmindWCF.exe.config and globalWCFClient.config files
    I will let you informed if I solve.
    thanks
  • Manuela Rodriguez
    Hi m_pdms
    just let you know the problem was the firewall and has been solved by IT.
    thank you for your support!
    Orlando de Oliveira Amaral dos Santos over 9 years ago
    The best way to test if there's a port blocking is using telnet, Manuela try to close a telnet session from your Hub to your Satellite using the following command:
    1- Open a DOS command prompt
    2- Type: telnet Sat_hostname 8000
    Where Sat_hostname is the hostname or ip address of your server, and port 8000 is the default port used by WCF. If the command prompt turn complete black your port is open, if you get an error message there's port blocking somewhere in your network.
    Cheers,
    Orlando
  • Manuela Rodriguez
    Thak you Orlando, good Typs!
