Iso Draft Weld Numbering with Prefix
  • Replies 9 replies
  • Subscribers 4 subscribers
  • Views 58 views
Atish naresh parkar
Atish naresh parkar over 15 years ago
  • Atish naresh parkar
    HI
    I am looking for weld numbering in isodrawing with weld prefix
    Currently we r getting Weld numbering as 1,2,3......
    i want it as J1,J2,J3...... which consist J as Prefix
    I tried to edit the weld prefix in spooler module to J and then extract they Iso
    but the result is same 1,2,3
    the Prefix comes only in weld table
    can anyone help me out in these issue
    how to bring the weld numbers with prefix ???
    Thanks in Advance
  • Admin
    Admin over 15 years ago
    [QUOTE=atish;38588]HI
    Thanks in Advance
    In spooler module we have 'WLDGRP' (weld group), if u get attributes form one 'IWELD' then we can see 'Wldprefix' .     Wldprefix 'J'.
    in isodraft module in option file >>> weld numbering we should change source to FROM DB , this means iso searching in Fabrication DB (spooler).
  • Admin
    alright, u can change the name too, and in option file set the name for weld.
    if u wont see the weld prefix get the DXF output file and in AutoCAD change wut u want!!!
    i think this is a good way.
    cheers
    hope it helps
  • Admin
    In autocad changing is easy, use that
    [QUOTE=brian;38997]In spooler module we have 'WLDGRP' (weld group), if u get attributes form one 'IWELD' then we can see 'Wldprefix' . Wldprefix 'J'.
    I have done the same setting but i cant see the weld number as J1,J2 on isometric
    but it represents on weld table
    have u tried it and is it working for u
    just send me a snap shot if its working at ur place
    thanks in advance
    [QUOTE=brian;39027]alright, u can change the name too, and in option file set the name for weld.
    cheers
    hope it helps
    thanks for ur brilliant idea
    hats of to u
    i am already using autolisp method and in one command i am changing it into J1 J2
    the question raised on pdms world so tht i can be able to solve it on PDMs itself.
    my friend
  • avwf_mosbricka86726542
    avwf_mosbricka86726542 over 15 years ago
    Doing the prefixes in autocad is not a good longterm solution to this problem.
    there should be some way to make the prefixes you set show up  directly on the isometric drawing rather than in a weld list.
    i e a bubbel within "J1", "J2" and so on.
  • Valentin COTOT
    Valentin COTOT 9 months ago
    15 years later still the same problem ...
    Corrado Galluzzi 9 months ago in reply to Valentin COTOT
    Dear Valentin, I would suggest you to open a Case  on Aveva Support Website and request for a product enhancement
