Iso Draft Tie-in Symbol
  • Replies 40 replies
  • Subscribers 4 subscribers
  • Views 167 views
Tie-in Symbol
Angello Padilla Maradiegue
Angello Padilla Maradiegue over 13 years ago
  • Angello Padilla Maradiegue
    Dear,
    I wish to place a Tie-in symbol in a pipe isometric but i do not find the way to do it. Is there any option to associate this symbol with a isometric?
    Regards
  • Russen Harold Cordovan
    Russen Harold Cordovan over 13 years ago
    [QUOTE=angellopadilla;56718]Dear,
    Regards
    could you post any drawing? but you can position any symbol in iso using atta using user-defined iso symbol. You can find the guide in isodraft user and reference manual.
    Corrado Galluzzi over 13 years ago
    I think you can use a comment atta. STEX can be set to 'TIE-IN 2'. And in isodraft you can use the OUTCOM command with Diamond shape on SUPP elements
    Then you can set MTOC attribute of ATTA to OFF in design.
    I am giving a training course.....so I could be wrong as I am trying to remember.....  :-)
    Try to do what you say but I can not even see the changes, use the command OUTC ATTY ON ALL WITH DIAM in the command line but nothing happens. Is there anything else I should do?
    Sorry...I was wrong !!!
    So....
    You can create an ATTA. Set its ATTY to WELD. Use a text type attribute (U.D.A.) and write 'TIE-IN 2' or anything you need. Set its MTOC attribute to OFF.
    Than you can modify your option file by adding: Outcom :MDSComment on SUPP with Boxstyle ANGLED
    As you can see I have used an existing MDS U.D.A.......I am a bit tired and lazy tonight..... :-)
    Do not use STEX attribute as you will display your text twice!
    It is probably a bit cumberstone....but it does the job!
    Hope this can help...
    Sorry. A little extra explanation. The reason why I would use ATTY WELD is because if you use ATTY HANG you get the Support symbol on your iso.....
    [QUOTE=angellopadilla;56793]Sorry, I made ​​a mistake, you are right. In Attribute is 'STEX' and in element is 'SUPP'.
    Thanks.
    If you do not need a baloon around your text, an ATTA with ATTY CCNN and STEX 'TIE-IN 2' is enough. No need to modify your option file!
    Thanks.
    Ok, I noticed. Thanks :)
