Iso Draft Text Alignment
  • Replies 10 replies
  • Subscribers 3 subscribers
  • Views 89 views
Text Alignment
Aaron Tan
Aaron Tan over 12 years ago
  • Admin
    Admin over 12 years ago
    it is possible to set some relations to other text
  • Aaron Tan
    Hey all,
    so under the directory "T:\Projects\projectsv12\APACHE\VARANUS\variso\std" i have an isometric option file. (a few actually).
    is there a way to justify and/or align the text to middle and centre?
    coz when you position an attribute text it has only the pos and the character height:
    TextPosition :PROJECT_TITLE X 400mm Y 27mm CharHeight 3.5mm
    In draft you would put:
    JUST Centre
    ALIGN HBODY
    Any thoughts?
  • Admin
    meanns previously defined
    you can set relations to their coordinates
  • Aaron Tan
    other texts meaning not those ones?
  • Aaron Tan
    but then wouldnt the text be left justified anyway?
  • marisa deleon
    marisa deleon over 10 years ago
    did anybody figure anything out about justification?  i too am trying to center justify instrument names in their bubbles and center justify my iso title text.  thanks
  • marisa deleon
    i'm wondering if we can put a pml expression in the iso plotfile forms (for the Xposition)?  i am trying to solve my text justification problem by using a number based on the LEN(NAME) but am having trouble with syntax.  has anybody done this?
  • marisa deleon
    Nevermind.  i figured it out.  Easy fix in the option file, as opposed to using the form!  duh!  (just learning...)
  • PaulCobb5735
    PaulCobb5735 over 9 years ago
    I am just learning as well and would like to know your fix in the option file.  Mine currently reads . . .
    Instname  NAME with balloon size 6
    Thank you.
  • Lev
    Lev over 2 years ago in reply to Aaron Tan
    Add next function (with name aligniso.pmlfnc) into your pmllib:
    define function !!aligniso (!inputtext is string, !x is real, !y is real, !charheig is real, !alignparam is string)
        !align = !alignparam.upcase()
        !z = !charheig * 0.7
        !l = !inputtext.length()
        if !align eq |R| then
            !x1 = !x -!l * !z
        elseif !align eq |C| then
            !x1 = !x - ( !l / 2 ) * !z
        else
            !x1 = !x
        endif
        !output = |TextPosition '$!inputtext' X $!x1 Y $!y charheight $!charheig|
       $!output
    endfunction
    In Option file use !!aligniso ('Project Title', 400,27,3.5, 'r'), instead of TextPosition ':PROJECT_TITLE' X 400mm Y 27mm CharHeight 3.5mm
    'r' - for right just
    'c' - for center just
    and '' - for left just
