Iso Draft Isometric material list
  • Replies 7 replies
  • Subscribers 4 subscribers
  • Views 305 views
bahman alavi
bahman alavi over 4 years ago
  • bahman alavi
    I can not increase the Length of itemcode. is there anyway to do this without increasing the length of Itemcode.
    Could you please confirm what you can or cannot do and why?
    Anyway, you can customize report columns, order and width as you like
  • SAMOEL JOINS
    SAMOEL JOINS over 4 years ago
    MaterialList GRIDLINES ON
    MaterialList TableDefinition  COLUMN 1 PARTNUMBER WITH WIDTH 3
    COLUMN 2 DESCRIPTION WITH WIDTH 45
    COLUMN 3 BORE WITH WIDTH 11
    Column 4 OTHER Heading 'COME CODE'  UDA NAME FROMSPCOM with Width 25
    COLUMN 5 QUANTITY IN MILLIMETRES WITH WIDTH 10
    Have you tried increasing the last column width?
    I do not think it will work as it is justified on the left if I am not wrong....
    So i believe you necessarily have to increase the itemcode width
  • bahman alavi
    [QUOTE=corrado;118952]Have you tried increasing the last column width?
    Look, My UDA has more character which I don't want in this column. If I increase the width, even in user-defined mode, those characters will appear in isometrics.
  • Atish naresh parkar
    Atish naresh parkar over 4 years ago
    you can control the length of Itemcode by having more then 1 uda for item code, like shortcode and longcode and you can call shortcode on the iso.
    how is your Materlist setup in isooption file ?
  • Mikael Bezerra Cotias dos Santos
    Mikael Bezerra Cotias dos Santos over 2 years ago in reply to SAMOEL JOINS
    Hi everyone, can we add a column like this:
    Column 4 OTHER Heading 'ISOMENTRIC NUMBER'  (:ISOMETRICNUMBER OF PIPE) with Width 50?
    Where the uda :ISOMETRICNUMBER is a pipe attribute
