Dear all
i have an instru ,i use skey CVFL and as shown in aveva recomendation,i set a p-point 11 to indicate orientation on isometrics.
the atext 346 is set on my config ISO but i dont have the indication on my drawing isometrics.
something particular to be check?? a purpose others?
thank you
Why don't you use P3?
Isodraft Reeference Manual says:
If an orientation p-point (P3) is present in the point set and is oriented away from the
XYZ axes, then the orientation of this p-point will be shown on the isometric.
[QUOTE=corrado;101144]Why don't you use P3?
Easy!
P3 is use for orientation of valv (or element ) about axe of pipe,i think he is not use for orientation of the pneumatic operator
[QUOTE=m_pdms;101150]I think P11 works only for VALV GTYP... and P11 is only for GEAR BOX orientation
change the Gtyp from INST to VALV.....
i thinked the same thing but no change,but i didn't try with the type of spco
