• [SIZE=2]Good Day,
    we have created separate spec for our Supports and some of the supports have Bearing PAD. PAD thickness will be the same as pipe but I don't know what will I use to put the Wall Thickness of the pipe to Dataset so that we can use it in the geometry of the PAD. I already tried the following.
    [FONT=arial]
    1. ATWALL / LTWALL - it will ok only in its previous/next component has TUBI, if multiple ATTA is [/FONT][/SIZE][/FONT]place, the succeeding[FONT="Times New Roman"][COLOR=#000000] [/COLOR][/FONT]ATTA [SIZE=2][FONT=arial]will have no ATWALL/LTWALL as it has 0mm TUBI lengthj
    2. PnWALL - I will not give any data since ATTA spec is different and it has no Pipe Data Table set in its SPEC.
    3. WTHICK OF ATWREF -  it gives correct value but cant be used in DATASET since I will UNSETRuse the DATA (It will became PROP)
    My current objective is that the thickness of the PAD will change based on its LSTUBE and to make a CATALOG which is common to all Pipe Schedule
    Please advise.
    thank you
    This is used in our In-House Support Utility.
    Our current solution is that there is function that will check the Wall Thickness and it will feed it in the ATTA as Desparam.[/SIZE]
  • we wish to do the same, only we want to have it for WELD instead of PAD.
