45degree Variable Angle Elbow
  • Dear prossly,
    can u please check Northing and Easting of Elbow and Terminal point. .
    it seems there is mismatch from attached image.
    Since i understand that slope is  applicable for Horizontal leg. Vertical leg and Rolled leg (45 Deg) will not have any slope and both legs are shown correctly.
  • Hi Elbows are available in market with 45 and 90 only.
    In ACP Also iam unable to find any component with DDANGLE FOR Elbow.
  • [QUOTE=deva;113053]Hi Elbows are available in market with 45 and 90 only.
    Hi deva,
    That case widely used for UG gravity pipes where the slope applied in horizontal spools and surely there is No slope in vertical portions. in addition, the Elbow restricted to 45degree angle so you have doted lines in the end where the TDIR is D. please, advise if you have a workaround.
  • Hi!
    One way to complete your vertikal line is ,
    to use Zero radius BEND .
    place one above the 45?elbo and one at the start at your "doted line"
    orient comp leave
    and you will see tube
    second way
    Change the angle of th 45deg elbo (where slope is ending)  [45deg minus slope degrees]
    $S-  -- Synonym translation OFF
    -- Data Listing    Date : 20 May 2016 11:56
    ONERROR GOLABEL /ERROR3
    INPUT BEGIN
    NEW SECTION /NEW_NE_ELBOW_45
    NEW DTSET /ELBOW_45_BW/DTSE
    NEW DATA /ELBOW_45_BW/DATA-W
    DKEY WEIG
    PPRO ( ATTRIB DESP[99 ] )
    DPRO ( 0 )
    PURP DESP
    NUMB 99
    DTIT 'WEIGHT'
    END
    END
    NEW GMSET /ELBOW_45_BW/GMSE
    NEW SCTORUS
    TUFL true
    PAAX P11
    PBAX P12
    PDIA ( ATTRIB PARA[21 ] + ATTRIB IPAR[1 ] )
    END
    NEW LCYLINDER
    TUFL true
    PTDI ( ATTRIB PARA[6 ] - ATTRIB PARA[19 ] )
    PBDI 0
    PDIA ( ATTRIB PARA[2 ] + ATTRIB IPAR[1 ] )
    PAXI P11
    END
    NEW LCYLINDER
    TUFL true
    PTDI ( ATTRIB PARA[12 ] - ATTRIB PARA[20 ] )
    PBDI 0
    PDIA ( ATTRIB PARA[8 ] + ATTRIB IPAR[1 ] )
    PAXI P12
    END
    NEW SCYLINDER
    TUFL true
    PDIS ( IFTRUE ( ATTRIB PARA[4 ] GT 0 , - ATTRIB PARA[4 ] / 2 , 0 ) )
    PDIA ( ATTRIB PARA[5 ] + ATTRIB IPAR[1 ] )
    PHEI ( IFTRUE ( ATTRIB PARA[4 ] GT 0 , ( ATTRIB PARA[4 ] + ABS ( ATTRIB PARA[4 ] ) ) / 2 + ATTRIB PARA[4 ] / 2 , ( $
    ATTRIB PARA[4 ] + ABS ( ATTRIB PARA[4 ] ) ) / 2 ) )
    PAXI P1
    END
    NEW SCYLINDER
    TUFL true
    PDIS - PARAM 31
    PHEI ( - ( ATTRIB PARA[4 ] + ABS ( ATTRIB PARA[4 ] ) ) / 2 + ATTRIB PARA[4 ] + ATTRIB PARA[31 ] )
    PAXI P1
    END
    NEW SCYLINDER
    OBST 0
    CLFL true
    PDIS 0
    PDIA ( 15 + 0.2 * ATTRIB PARA[1 ] )
    PHEI ( ( ATTRIB PARA[4 ] + ABS ( ATTRIB PARA[4 ] ) ) / 2 )
    PAXI P1
    END
    NEW SCYLINDER
    TUFL true
    PDIS ( IFTRUE ( ATTRIB PARA[10 ] GT 0 , - ATTRIB PARA[10 ] / 2 , 0 ) )
    PDIA ( ATTRIB PARA[11 ] + ATTRIB IPAR[1 ] )
    PHEI ( IFTRUE ( ATTRIB PARA[10 ] GT 0 , ( ATTRIB PARA[10 ] + ABS ( ATTRIB PARA[10 ] ) ) / 2 + ATTRIB PARA[10 ] / 2 , ( $
    ATTRIB PARA[10 ] + ABS ( ATTRIB PARA[10 ] ) ) / 2 ) )
    PAXI P2
    END
    NEW SCYLINDER
    TUFL true
    PDIS - PARAM 32
    PHEI ( - ( ATTRIB PARA[10 ] + ABS ( ATTRIB PARA[10 ] ) ) / 2 + ATTRIB PARA[10 ] + ATTRIB PARA[32 ] )
    PAXI P2
    END
    NEW SCYLINDER
    OBST 0
    CLFL true
    PDIS 0
    PDIA ( 15 + 0.2 * ATTRIB PARA[7 ] )
    PHEI ( ( ATTRIB PARA[10 ] + ABS ( ATTRIB PARA[10 ] ) ) / 2 )
    PAXI P2
    END
    NEW LCYLINDER
    CLFL true
    TUFL true
    PTDI - PARAM 31
    PBDI 0
    PDIA ( 0.75 * ATTRIB PARA[5 ] )
    PAXI P1
    END
    NEW LCYLINDER
    CLFL true
    TUFL true
    PTDI - PARAM 32
    PBDI 0
    PDIA ( 0.75 * ATTRIB PARA[11 ] )
    PAXI P2
    END
    NEW LINE
    OBST 0
    CLFL true
    SETP P1 P11
    END
    NEW LINE
    OBST 0
    CLFL true
    SETP P2 P12
    END
    NEW LINE
    OBST 0
    CLFL true
    SETP P11 T0 P12
    END
    NEW SSPHERE
    OBST 0
    CLFL true
    PDIS 0
    PAXI P1
    END
    NEW SSPHERE
    OBST 0
    CLFL true
    PDIS 0
    PAXI P2
    END
    END
    NEW PTSET /ELBOW_45_BW/PTSE
    NEW PTCAR
    NUMB 1
    PCON PARAM 3
    PBOR PARAM 1
    PX ( -1 * ATTRIB PARA[6 ] * TAN ( MIN ( 45 , ATTRIB ANGL ) ) )
    PY 0
    PZ 0
    PTCDI AXIS -X
    PZAXI Z
    END
    NEW PTCAR
    NUMB 11
    PCON PARAM 3
    PBOR PARAM 1
    PY 0
    PZ 0
    PTCDI AXIS -X
    PZAXI Z
    END
    NEW PTCAR
    NUMB 2
    PCON PARAM 9
    PBOR PARAM 7
    PX ( ATTRIB PARA[12 ] * TAN ( MIN ( 45 , ATTRIB ANGL ) ) * COS ( MIN ( 45 , ATTRIB ANGL ) ) )
    PY ( ATTRIB PARA[12 ] * TAN ( MIN ( 45 , ATTRIB ANGL ) ) * SIN ( MIN ( 45 , ATTRIB ANGL ) ) )
    PZ 0
    PTCDI X ( MIN ( 45 , ATTRIB ANGL ) ) Y
    PZAXI Z
    END
    NEW PTCAR
    NUMB 12
    PCON PARAM 9
    PBOR PARAM 7
    PZ 0
    PZAXI Z
    END
    END
    NEW TEXT /NEW_ELBOW_45
    END
    NEW CATEGORY /NAEC200
    GTYP ELBO
    NEW TEXT /NAEC200-PA01
    STEX 'DN_1'
    END
    NEW TEXT /NAEC200-PA02
    STEX 'DIA_1'
    END
    NEW TEXT /NAEC200-PA03
    STEX 'CON_1'
    END
    NEW TEXT /NAEC200-PA04
    STEX 'EP_1'
    END
    NEW TEXT /NAEC200-PA05
    STEX 'DIA_CON1'
    END
    NEW TEXT /NAEC200-PA06
    STEX 'DIST_1'
    END
    NEW TEXT /NAEC200-PA07
    STEX 'DN_2'
    END
    NEW TEXT /NAEC200-PA08
    STEX 'DIA_2'
    END
    NEW TEXT /NAEC200-PA09
    STEX 'CON_2'
    END
    NEW TEXT /NAEC200-PA10
    STEX 'EP_2'
    END
    NEW TEXT /NAEC200-PA11
    STEX 'DIA_CON2'
    END
    NEW TEXT /NAEC200-PA12
    STEX 'DIST_2'
    END
    NEW TEXT /NAEC200-PA13
    STEX 'DN_3'
    END
    NEW TEXT /NAEC200-PA14
    STEX 'DIA_3'
    END
    NEW TEXT /NAEC200-PA15
    STEX 'CON_3'
    END
    NEW TEXT /NAEC200-PA16
    STEX 'EP_3'
    END
    NEW TEXT /NAEC200-PA17
    STEX 'DIA_CON3'
    END
    NEW TEXT /NAEC200-PA18
    STEX 'DIST_3'
    END
    NEW TEXT /NAEC200-PA19
    STEX 'Spare'
    END
    NEW TEXT /NAEC200-PA20
    STEX 'Spare'
    END
    NEW TEXT /NAEC200-PA21
    STEX 'DIA_CORPS'
    END
    NEW TEXT /NAEC200-PA22
    STEX 'LARGEUR'
    END
    NEW TEXT /NAEC200-PA23
    STEX 'P_BAS'
    END
    NEW TEXT /NAEC200-PA24
    STEX 'P_HAUT'
    END
    NEW TEXT /NAEC200-PA25
    STEX 'DIA_ACT'
    END
    NEW TEXT /NAEC200-PA26
    STEX 'DIA_CORPS_OBS'
    END
    NEW TEXT /NAEC200-PA27
    STEX 'LARGEUR_OBS'
    END
    NEW TEXT /NAEC200-PA28
    STEX 'P_BAS_OBS'
    END
    NEW TEXT /NAEC200-PA29
    STEX 'P_HAUT_OBS'
    END
    NEW TEXT /NAEC200-PA30
    STEX 'DIA_ACT_OBS'
    END
    NEW TEXT /NAEC200-PA31
    STEX 'THICKNESS_FF_1'
    END
    NEW TEXT /NAEC200-PA32
    STEX 'THICKNESS_FF_2'
    END
    NEW TEXT /NAEC200-PA33
    STEX 'THICKNESS_FF_3'
    END
    NEW SDTEXT /NAEC200/SDTE
    SKEY 'ELBW'
    RTEX ( 'ELBOW 45 D LR BW ASME B16.9 ' + ATTRIB DESC OF PDAREF OF SPRE  )
    STEX ( 'ELBOW 45 D LR BW ' + ATTRIB DESC OF PDAREF OF SPRE  )
    TTEX 'ELBOW 45'
    END
    NEW SCOMPONENT /NAEC200AA
    GTYP ELBO
    PARA 6 10.3 BWD 0 0 $
    0 6 10.3 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    10.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200BB
    GTYP ELBO
    PARA 8 13.7 BWD 0 0 $
    0 8 13.7 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    13.7 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200CC
    GTYP ELBO
    PARA 10 17.1 BWD 0 0 $
    0 10 17.1 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    17.1 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200DD
    GTYP ELBO
    PARA 15 21.3 BWD 0 0 $
    16 15 21.3 BWD 0 $
    0 16 0 0 0 $
    0 0 0 16 16 $
    21.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200EE
    GTYP ELBO
    PARA 20 26.7 BWD 0 0 $
    11 20 26.7 BWD 0 $
    0 11 0 0 0 $
    0 0 0 11 11 $
    26.7 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200FF
    GTYP ELBO
    PARA 25 33.4 BWD 0 0 $
    22 25 33.4 BWD 0 $
    0 22 0 0 0 $
    0 0 0 22 22 $
    33.4 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200GG
    GTYP ELBO
    PARA 32 42.2 BWD 0 0 $
    25 32 42.2 BWD 0 $
    0 25 0 0 0 $
    0 0 0 25 25 $
    42.2 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200HH
    GTYP ELBO
    PARA 40 48.3 BWD 0 0 $
    29 40 48.3 BWD 0 $
    0 29 0 0 0 $
    0 0 0 29 29 $
    48.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200JJ
    GTYP ELBO
    PARA 50 60.3 BWD 0 0 $
    35 50 60.3 BWD 0 $
    0 35 0 0 0 $
    0 0 0 35 35 $
    60.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200KK
    GTYP ELBO
    PARA 65 73 BWD 0 0 $
    44 65 73 BWD 0 $
    0 44 0 0 0 $
    0 0 0 44 44 $
    73 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200LL
    GTYP ELBO
    PARA 80 88.9 BWD 0 0 $
    51 80 88.9 BWD 0 $
    0 51 0 0 0 $
    0 0 0 51 51 $
    88.9 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200MM
    GTYP ELBO
    PARA 90 101.6 BWD 0 0 $
    57 90 101.6 BWD 0 $
    0 57 0 0 0 $
    0 0 0 57 57 $
    101.6 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200NN
    GTYP ELBO
    PARA 100 114.3 BWD 0 0 $
    64 100 114.3 BWD 0 $
    0 64 0 0 0 $
    0 0 0 64 64 $
    114.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200PP
    GTYP ELBO
    PARA 125 141.3 BWD 0 0 $
    79 125 141.3 BWD 0 $
    0 79 0 0 0 $
    0 0 0 79 79 $
    141.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200RR
    GTYP ELBO
    PARA 150 168.3 BWD 0 0 $
    95 150 168.3 BWD 0 $
    0 95 0 0 0 $
    0 0 0 95 95 $
    168.3 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200TT
    GTYP ELBO
    PARA 200 219.1 BWD 0 0 $
    127 200 219.1 BWD 0 $
    0 127 0 0 0 $
    0 0 0 127 127 $
    219.1 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200VV
    GTYP ELBO
    PARA 250 273 BWD 0 0 $
    159 250 273 BWD 0 $
    0 159 0 0 0 $
    0 0 0 159 159 $
    273 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200WW
    GTYP ELBO
    PARA 300 323.8 BWD 0 0 $
    191 300 323.8 BWD 0 $
    0 191 0 0 0 $
    0 0 0 191 191 $
    323.8 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200XX
    GTYP ELBO
    PARA 350 355.6 BWD 0 0 $
    222 350 355.6 BWD 0 $
    0 222 0 0 0 $
    0 0 0 222 222 $
    355.6 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200YY
    GTYP ELBO
    PARA 400 406.4 BWD 0 0 $
    254 400 406.4 BWD 0 $
    0 254 0 0 0 $
    0 0 0 254 254 $
    406.4 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200ZZ
    GTYP ELBO
    PARA 450 457 BWD 0 0 $
    286 450 457 BWD 0 $
    0 286 0 0 0 $
    0 0 0 286 286 $
    457 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20011
    GTYP ELBO
    PARA 500 508 BWD 0 0 $
    318 500 508 BWD 0 $
    0 318 0 0 0 $
    0 0 0 318 318 $
    508 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20022
    GTYP ELBO
    PARA 550 559 BWD 0 0 $
    343 550 559 BWD 0 $
    0 343 0 0 0 $
    0 0 0 343 343 $
    559 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20033
    GTYP ELBO
    PARA 600 610 BWD 0 0 $
    381 600 610 BWD 0 $
    0 381 0 0 0 $
    0 0 0 381 381 $
    610 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20044
    GTYP ELBO
    PARA 650 660 BWD 0 0 $
    406 650 660 BWD 0 $
    0 406 0 0 0 $
    0 0 0 406 406 $
    660 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20055
    GTYP ELBO
    PARA 700 711 BWD 0 0 $
    438 700 711 BWD 0 $
    0 438 0 0 0 $
    0 0 0 438 438 $
    711 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20066
    GTYP ELBO
    PARA 750 762 BWD 0 0 $
    470 750 762 BWD 0 $
    0 470 0 0 0 $
    0 0 0 470 470 $
    762 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20077
    GTYP ELBO
    PARA 800 813 BWD 0 0 $
    502 800 813 BWD 0 $
    0 502 0 0 0 $
    0 0 0 502 502 $
    813 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20088
    GTYP ELBO
    PARA 850 864 BWD 0 0 $
    533 850 864 BWD 0 $
    0 533 0 0 0 $
    0 0 0 533 533 $
    864 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC20099
    GTYP ELBO
    PARA 900 914 BWD 0 0 $
    584 900 914 BWD 0 $
    0 584 0 0 0 $
    0 0 0 584 584 $
    914 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200aa
    GTYP ELBO
    PARA 950 0 BWD 0 0 $
    0 950 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200bb
    GTYP ELBO
    PARA 1000 0 BWD 0 0 $
    0 1000 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200cc
    GTYP ELBO
    PARA 1050 0 BWD 0 0 $
    0 1050 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200dd
    GTYP ELBO
    PARA 1100 0 BWD 0 0 $
    0 1100 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200ee
    GTYP ELBO
    PARA 1150 0 BWD 0 0 $
    0 1150 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    NEW SCOMPONENT /NAEC200ff
    GTYP ELBO
    PARA 1200 0 BWD 0 0 $
    0 1200 0 BWD 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0 0 0 $
    0 0 0
    END
    END
    END
    OLD CATEGORY /NAEC200
    PTRE PTSET /ELBOW_45_BW/PTSE
    GMRE GMSET /ELBOW_45_BW/GMSE
    DTRE DTSET /ELBOW_45_BW/DTSE
    OLD SCOMPONENT /NAEC200AA
    OLD SCOMPONENT /NAEC200BB
    OLD SCOMPONENT /NAEC200CC
    OLD SCOMPONENT /NAEC200DD
    OLD SCOMPONENT /NAEC200EE
    OLD SCOMPONENT /NAEC200FF
    OLD SCOMPONENT /NAEC200GG
    OLD SCOMPONENT /NAEC200HH
    OLD SCOMPONENT /NAEC200JJ
    OLD SCOMPONENT /NAEC200KK
    OLD SCOMPONENT /NAEC200LL
    OLD SCOMPONENT /NAEC200MM
    OLD SCOMPONENT /NAEC200NN
    OLD SCOMPONENT /NAEC200PP
    OLD SCOMPONENT /NAEC200RR
    OLD SCOMPONENT /NAEC200TT
    OLD SCOMPONENT /NAEC200VV
    OLD SCOMPONENT /NAEC200WW
    OLD SCOMPONENT /NAEC200XX
    OLD SCOMPONENT /NAEC200YY
    OLD SCOMPONENT /NAEC200ZZ
    OLD SCOMPONENT /NAEC20011
    OLD SCOMPONENT /NAEC20022
    OLD SCOMPONENT /NAEC20033
    OLD SCOMPONENT /NAEC20044
    OLD SCOMPONENT /NAEC20055
    OLD SCOMPONENT /NAEC20066
    OLD SCOMPONENT /NAEC20077
    OLD SCOMPONENT /NAEC20088
    OLD SCOMPONENT /NAEC20099
    OLD SCOMPONENT /NAEC200aa
    OLD SCOMPONENT /NAEC200bb
    OLD SCOMPONENT /NAEC200cc
    OLD SCOMPONENT /NAEC200dd
    OLD SCOMPONENT /NAEC200ee
    OLD SCOMPONENT /NAEC200ff
    INPUT END  SECTION /NEW_NE_ELBOW_45
    INPUT FINISH
    -- Switch synonyms back on if an error occurs.
    LABEL /ERROR3
    handle ANY
    $S+
    RETURN ERROR
    endhandle
    -- End Data Listing    Date : 20 May 2016 11:56
    $S+  -- Synonym translation ON
  • Hope this helps....
    Thanks so much Corrado, the problem is fixed right now.
