Paragon Module
DataSet in SCOM to get the height of extended stem of a valve from UDA in SPREF?
6 subscribers
Mohammad Refaie
over 5 years ago
Mohammad Refaie
over 5 years ago
Good day,
Can I create a dataSet in SCOM to get the height of extended stem of a valve from UDA in SPREF?
Eric Callis
over 5 years ago
Why not simply make this value a Design Parameter that feeds your dataset?
Mohammad Refaie
over 5 years ago
To make the data centralized in one place, as each valve with a certain stem height has a certain item code, and it shouldn't be under control of each designer.
Eric Callis
over 5 years ago
If it is catalog driven then make it a parameter. I don't think you can access a UDA of a SPCO from an SCOM except by name. Seems backwards.
