Can anybody DB list their Field Fit Weld from the Catalog and post here please!
My Field Fit Weld component is built incorrectly and I cannot figure out why - would be nice to compare to yours if yours is working properly.
Your help is much appreciated.
PAXI is the axes direction attribute of the PTAX point....
Take a look at the Aveva supplied category named /MODELLED.WELDS.FIELD.FITTING.FITTING as comparison.
As I said, you could copy/paste that. You just need to modify the Lay length according to your needs
Yes there is one but its not build properly. I have talked with Aveva support and they even said this on our call. We didn't have time to troubleshoot at the time of a call. They were going to supply me a good copy of it but its been two weeks and I haven't heard from anybody...
I fixed the P-Points to say X (for P-Point 1) and -X (for P-Point 2) but that did not work. You said PAXI ... mine are PTAX,..., Could that make a difference?
