Currently iam working with Paragon and creating Control valves etc.
Iam facing issue that i cannot manage component creation with Single Geometry set. Due to typical geometries i need to create GMSE differently for each bore.
i need tips on how to create components even though typical with single geometry sets.
You need, but you can not? Why?
You could define parameters that, for example, if the value is set to zero, the corresponding 3D primitive will disappear.
But if you can manage to add/modify parameters then you could even create new GMSEs as joge suggested
