Paragon Module Equivalent Metric Bolt - 1
  • Replies 9 replies
  • Subscribers 6 subscribers
  • Views 41 views
THANGA PANDI
THANGA PANDI over 4 years ago
  • THANGA PANDI
  • Josef Geltl
    Josef Geltl over 4 years ago
    I had similar situation, but DIN-Flanges with ANSI-Bolts.
    My Method was:
    I copyed the DIN-flanges CATES and referenced the appropriate ANSI-bolting BTSES
    You have to copy your ANSI-FLANGE CATE`s,
    create appropriate BTSE`s, LTAB (DTAB), BLIS (SBOL) in your CATA (if not already exists)
    You have to create a boltspec with your DIN-Bolts and Nuts too.
    After referencing the BTSE?s to the SCOMS, you have to include the new Flanges into your
    appropriate Pipe-SPEC?s.
    Normaly at the Equi-Nozzles is nothing to change.
    Maybe there is a different (more elegant) way to do this. But as I mentioned above that was my way!
    In your table is something wrong, 0.5Inch bolt isnt M14. It is similar to M12!
    I didnt check the other entrys.
  • THANGA PANDI
    Thanks for your reply Joge!!
    I have done the BOLT related setup in spec.
    But I need the technical confirmation for that table values to be used for imperial and metric conversion?
    As you mentioned 0.5 inch  = M12.But I can't get any kind of standard or document for this values conversion.
    Kindly provide if you have!!
    -stpandi
  • Josef Geltl
    Hi!
    M16 means boltdiam 16mm
    M27 means boltdiam 27mm
    a.so
    It depends on your clients spec.
    There are different Bolt Specifications like DIN-Spec, EN-Spec, ISO-Spec.
    for ex.
    DIN2510 for bolt with two nuts
    EN ISO 4014, EN ISO 4017 for mach-bolts EN ISO 4032 for required nuts
    a.so
    So you have to inform by yourself
  • THANGA PANDI
  • Josef Geltl
    Your pictures looks good
    but i can read nearly nothing (to smal)
  • THANGA PANDI
    Hi Joge!!
    What about linkpicture link image.is it also small?
    https://www.linkpicture.com/q/bolt.png
    -stpandi
  • Josef Geltl
    No that?s OK!
  • Fariza I
    Fariza I over 3 years ago
    thanks for sharing bolt dimension
