Paragon Module
If statement in dataset property.
6 subscribers
vivek chudasama
over 10 years ago
Corrado Galluzzi
over 10 years ago
I would try using IFTRUE syntax...
Corrado Galluzzi
over 10 years ago
Serach for IFTRUE in the forum...
For example http://52.178.132.139/showthread.php?t=13597
I am not sure what you want to achieve....but it could be something like:
IFTRUE(DESPARA1 EQ 'X', X, -X)
vivek chudasama
over 10 years ago
How to set If statement in dataset in paragon.
Like,
IF desparam 1 eq x so set x else -x.
vivek chudasama
over 10 years ago
hi corrado,
how you will use the IFTRUE syntax in dataset please give some example.
ZhaoChaoli
over 10 years ago
IFTRUE(DESP[1] EQ X,X,-X)
By the way, where X is real type.
Joy PA
over 4 years ago
Hi Carrado,
I am trying to use IFTRUE condition for calling MAterial reference in E3D support. Bellow line i used for adding Support type in Support code. But i am getting incomplete command line error. Kindly advice whats the error.
q IFTRUE(Matref eq '/STAINLESS/STEEL','B','L').
Thanks in Advance...
Corrado Galluzzi
over 4 years ago
Try with NAME OF MATREF
Joy PA
over 4 years ago
Yes its working.. Thanks [COLOR=#3E3E3E]Corrado[/COLOR]
