FOR CREATING HALF COUPLING AS BRANCH CONNECTION DO WE NEED TO MODIFY SOCKOLET CATE for creating half cplg as in sample we donot have any coupling which three points as it has p1 and p2 points
You can find several "Tee by half coupling" categories in the Aveva supplied piping catalogue
I HAVE ONE MORE QUESTION CAN WE SET OPTION FILE IN DESIGN FOR EXTRACTING ISOMETRICS AND SET DRAWING
your config file should be named : previewisostd.txt and should be in project directory ....\xxiso\std
IF we donot have the file when extracting isometric from design ho w we set backing seet in design template in e3d design and link it up
Hi Corrado,
The how do extract the half coupling which will be appearing as tee for branch collection so what should the skey be set for half coupling to appear properly in isodraft module.
Regards,
Anindya Ganguly
I wpould use HC**
I suggest you to read Isodraft Reference Manual. Symbol Keys Chapter. TEE or OLET paragraph
okay corrado mostly it acts as weldolet when we branch out using at half coupling actually it is acting as a olet
