How to edit in secondary support ??
  • hi it seems it is a Framework,
    In template you have to do changes rotation etc
  • But how to ensure its already made within Paragon list Available as well ?
  • hi surya
    i will give steps for this today iam searching about this
    certain parameters are exported to excel from existing frames and it should be imported to paragon database with changing name
    FT08 TO FT508
    I will send examples tomorrow
  • Thank you Mr.Deva.
    I appreciate your keen  and Straight answers
    I will you wait for your reply with the answer
    $S-  -- Synonym translation OFF
    -- Data Listing    Date : 27 Feb 2020 12:21
    ONERROR GOLABEL /ERROR3
    INPUT BEGIN
    NEW ZONE /MDS/FRAMES/FT508
    PURP NONE
    POS E 9000mm N 0mm U 0mm
    :MDSCp1 'FT508'
    NEW STRUCTURE /MDS/FT508/1
    DESC '60x60x8 Angle, Internally Welded'
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/1-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/1-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    BANG -90degree
    DRNE W
    POSS W 60mm N 17mm D 17.7mm
    POSE E 60mm N 17mm D 17.7mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/60x60x8.0
    MEML NA
    END
    NEW SCTN /MDS/FT508/1-V1
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 17.7mm N 52.4mm D 190mm
    POSE E 17.7mm N 52.4mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/1-V2
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 17.7mm N 52.4mm D 190mm
    POSE W 17.7mm N 52.4mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/2
    DESC '80x80x10 Angle, Internally Welded'
    POS E 0mm N 200mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/2-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/2-BAR-1
    GTYP ANG
    DESP 1180
    BUIL false
    SHOP false
    BANG -90degree
    DRNE W
    POSS W 80mm N 22mm D 23.4mm
    POSE E 80mm N 22mm D 23.4mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/80x80x10.0
    MEML NA
    END
    NEW SCTN /MDS/FT508/2-V1
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 23.5mm N 68.8mm D 210mm
    POSE E 23.5mm N 68.8mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/2-V2
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 23.3mm N 68.8mm D 210mm
    POSE W 23.3mm N 68.8mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/3
    DESC '100x100x12 Angle, Internally Welded'
    POS E 0mm N 400mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/3-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/3-BAR-1
    GTYP ANG
    DESP 1720
    BUIL false
    SHOP false
    BANG -90degree
    DRNE W
    POSS W 100mm N 25.6mm D 29mm
    POSE E 100mm N 25.6mm D 29mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/100x100x12.0
    MEML NA
    END
    NEW SCTN /MDS/FT508/3-V1
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 29mm N 83.6mm D 230mm
    POSE E 29mm N 83.6mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/3-V2
    GTYP ANG
    DESP 990
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 29mm N 83.6mm D 230mm
    POSE W 29mm N 83.6mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/4
    DESC '152 x 89 Channel, Internally Welded'
    POS E 0mm N 650mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/4-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/4-BAR-1
    GTYP CHAN
    DESP 1824
    BUIL false
    SHOP false
    BANG 180degree
    DRNE W
    POSS W 152.4mm N 27mm D 76.2mm
    POSE E 152.4mm N 27mm D 76.2mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/152x89RSC
    MEML NA
    END
    NEW SCTN /MDS/FT508/4-V1
    GTYP CHAN
    DESP 990
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 76.2mm N 84mm D 283mm
    POSE E 76.2mm N 84mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/4-V2
    GTYP CHAN
    DESP 990
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 76.2mm N 84mm D 283mm
    POSE W 76.2mm N 84mm U 0mm
    JLIN NA
    JUSL NA
    GRADE 0
    FIRE 0
    MEML NA
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/5
    DESC '60x60x8 Angle, Internally Bolted'
    POS E 0mm N 1000mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/5-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/5-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNE W
    POSS W 50.3mm S 17.3mm D 17.7mm
    POSE E 50.3mm S 17.3mm D 17.7mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/5-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 78mm S 17mm D 200mm
    POSE E 78mm S 17mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/5-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/5-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAT
    BANG 180degree
    CUTB 10mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-Angle_End_Plate_Right_Down
    END
    END
    END
    NEW SCTN /MDS/FT508/5-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 78mm S 17.3mm D 200mm
    POSE W 78mm S 17.3mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/5-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/5-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAL
    BANG 180degree
    CUTB 10mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-Angle_End_Plate_Left_Down
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/6
    DESC '80x80x10 Angle, Internally Bolted'
    POS E 0mm N 1200mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/6-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/6-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNE W
    POSS W 44.6mm S 21.3mm D 23.7mm
    POSE E 44.6mm S 21.3mm D 23.7mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/6-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 78mm S 21mm D 200mm
    POSE E 78mm S 21mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/6-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/6-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAT
    BANG 180degree
    CUTB 10mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    NEW SCTN /MDS/FT508/6-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 78mm S 21.3mm D 200mm
    POSE W 78mm S 21.3mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/6-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/6-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAL
    BANG 180degree
    CUTB 10mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/7
    DESC '100x100x12 Angle, Internally Bolted'
    POS E 0mm N 1400mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/7-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/7-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNE W
    POSS W 39mm S 26.3mm D 28.7mm
    POSE E 39mm S 26.3mm D 28.7mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/7-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 78mm S 26mm D 200mm
    POSE E 78mm S 26mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/7-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/7-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAT
    BANG 180degree
    CUTB 10mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    NEW SCTN /MDS/FT508/7-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE D
    POSS W 78mm S 26.3mm D 200mm
    POSE W 78mm S 26.3mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/7-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/7-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NAL
    BANG 180degree
    CUTB 10mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/8
    DESC '152 x 89 Channel, Internally Bolted'
    POS E 0mm N 1650mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/8-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/8-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNE W
    POSS W 91.8mm S 27.3mm D 75.7mm
    POSE E 91.8mm S 27.3mm D 75.7mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    END
    NEW SCTN /MDS/FT508/8-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS E 178mm S 27mm D 200mm
    POSE E 178mm S 27mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/8-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/8-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL TOC
    BANG 180degree
    CUTB 10mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-Channel_End_Plate
    END
    END
    END
    NEW SCTN /MDS/FT508/8-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 178mm S 27.3mm D 200mm
    POSE W 178mm S 27.3mm U 0mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'FLUSH'
    NEW SNODE /MDS/FT508/8-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/8-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL BOC
    CUTB 10mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/9
    DESC 'HALFEN 41/22 Channel'
    POS E 0mm N 1900mm U 0mm
    BUIL false
    PDNAME unset
    :MDSMaxBore 25
    NEW FRMWORK /MDS/FT508/9-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/9-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    BANG 180degree
    DRNE W
    POSS W 91.8mm N 0mm D 10.5mm
    POSE E 91.8mm N 0mm D 10.5mm
    JLIN NA
    JUSL NA
    CTYS BOLT
    CTYE BOLT
    GRADE 0
    FIRE 0
    SPRE SPRFILE /HZL41/22
    MEML NA
    END
    NEW SCTN /MDS/FT508/9-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG -90degree
    DRNS U
    DRNE D
    POSS E 102.3mm N 0mm D 200mm
    POSE E 102.3mm N 0mm U 100mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 50
    NEW SNODE /MDS/FT508/9-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/9-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -10.5mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-HCS-VT41-68/2
    END
    END
    END
    NEW SCTN /MDS/FT508/9-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 102.3mm N 0mm D 200mm
    POSE W 102.3mm N 0mm U 100mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 50
    NEW SNODE /MDS/FT508/9-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/9-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -10.5mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/10
    DESC 'HALFEN 41/41 Channel'
    POS E 0mm N 2150mm U 0mm
    BUIL false
    PDNAME unset
    :MDSMaxBore 80
    NEW FRMWORK /MDS/FT508/10-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/10-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    BANG 180degree
    DRNE W
    POSS W 91.8mm N 0mm D 20.5mm
    POSE E 91.8mm N 0mm D 20.5mm
    JLIN NA
    JUSL NA
    CTYS BOLT
    CTYE BOLT
    GRADE 0
    FIRE 0
    SPRE SPRFILE /HZL41/41
    MEML NA
    END
    NEW SCTN /MDS/FT508/10-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG -90degree
    DRNS U
    DRNE D
    POSS E 112.3mm N 0mm D 200mm
    POSE E 112.3mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 120
    NEW SNODE /MDS/FT508/10-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/10-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -20.5mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-HCS-VT41-26/1
    END
    END
    END
    NEW SCTN /MDS/FT508/10-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 112.3mm N 0mm D 200mm
    POSE W 112.3mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 120
    NEW SNODE /MDS/FT508/10-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/10-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -20.5mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/11
    DESC 'HALFEN 41/22D Channel'
    POS E 0mm N 2400mm U 0mm
    BUIL false
    PDNAME unset
    :MDSMaxBore 80
    NEW FRMWORK /MDS/FT508/11-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/11-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    BANG 180degree
    DRNE W
    POSS W 92.3mm N 0mm D 21mm
    POSE E 92.3mm N 0mm D 21mm
    JLIN NA
    JUSL NA
    CTYS BOLT
    CTYE BOLT
    GRADE 0
    FIRE 0
    SPRE SPRFILE /HZM41/22D
    MEML NA
    END
    NEW SCTN /MDS/FT508/11-V1
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG -90degree
    DRNS U
    DRNE D
    POSS E 112.8mm N 0mm D 200mm
    POSE E 112.8mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 120
    NEW SNODE /MDS/FT508/11-V1/S1
    ZDIS 182.3mm
    NEW SJOINT /MDS/FT508/11-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -20.5mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    NEW SCTN /MDS/FT508/11-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 112.8mm N 0mm D 200mm
    POSE W 112.8mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 120
    NEW SNODE /MDS/FT508/11-V2/S1
    ZDIS 182mm
    NEW SJOINT /MDS/FT508/11-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -20.5mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/12
    DESC 'HALFEN 63/63 Channel'
    POS E 0mm N 2650mm U 0mm
    BUIL false
    PDNAME unset
    :MDSMaxBore 150
    NEW FRMWORK /MDS/FT508/12-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/12-BAR-1
    GTYP HALS
    DESP 1140
    BUIL false
    SHOP false
    BANG 180degree
    DRNE W
    POSS W 191.8mm N 0mm D 31.5mm
    POSE E 191.8mm N 0mm D 31.5mm
    JLIN NA
    JUSL NA
    CTYS BOLT
    CTYE BOLT
    GRADE 0
    FIRE 0
    SPRE SPRFILE /HZL63/63
    MEML NA
    END
    NEW SCTN /MDS/FT508/12-V1
    GTYP HALS
    DESP 1070
    BUIL false
    SHOP false
    BANG -90degree
    DRNS U
    DRNE D
    POSS E 223.3mm N 0mm D 200mm
    POSE E 223.3mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 100
    NEW SNODE /MDS/FT508/12-V1/S1
    ZDIS 168.5mm
    NEW SJOINT /MDS/FT508/12-V1/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    BANG 180degree
    CUTB -31.5mm
    CUTP W
    JLIN NA
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /MDS-HCS-VT63-21/4-fv
    END
    END
    END
    NEW SCTN /MDS/FT508/12-V2
    GTYP HALS
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE D
    POSS W 223.3mm N 0mm D 200mm
    POSE W 223.3mm N 0mm U 150mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum 100
    NEW SNODE /MDS/FT508/12-V2/S1
    ZDIS 168.5mm
    NEW SJOINT /MDS/FT508/12-V2/S1/IJOINT1
    BUIL false
    SHOP false
    POSL NA
    CUTB -31.5mm
    CUTP E
    JLIN NA
    GRADE 0
    FIRE 0
    END
    END
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/13
    DESC '50x50x6 Angle, Mitred Corners'
    PURP MITR
    POS E 0mm N 3200mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/13-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/13-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNS E 45 U
    DRNE W 45 U
    POSS W 50.3mm S 16.5mm D 14.5mm
    POSE E 50.3mm S 16.5mm D 14.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/50x50x6.0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -14.5
    END
    NEW SCTN /MDS/FT508/13-V1
    PURP MITR
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE W 45 U
    POSS E 50.3mm S 16.2mm D 214.5mm
    POSE E 50.3mm S 16.2mm D 14.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -14.5
    END
    NEW SCTN /MDS/FT508/13-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE E 45 U
    POSS W 50.3mm S 16.5mm D 214.5mm
    POSE W 50.3mm S 16.5mm D 14.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -14.5
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/14
    DESC '60x60x10 Angle, Mitred Corners'
    PURP MITR
    POS E 0mm N 3400mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/14-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/14-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNS E 45 U
    DRNE W 45 U
    POSS W 50.3mm S 16.5mm D 18.5mm
    POSE E 50.3mm S 16.5mm D 18.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/60x60x10.0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -18.5
    END
    NEW SCTN /MDS/FT508/14-V1
    PURP MITR
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE W 45 U
    POSS E 50.3mm S 16.2mm D 218.5mm
    POSE E 50.3mm S 16.2mm D 18.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -18.5
    END
    NEW SCTN /MDS/FT508/14-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE E 45 U
    POSS W 50.3mm S 16.5mm D 218.5mm
    POSE W 50.3mm S 16.5mm D 18.5mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -18.5
    END
    END
    END
    NEW STRUCTURE /MDS/FT508/15
    DESC '70x70x10 Angle, Mitred Corners'
    PURP MITR
    POS E 0mm N 3600mm U 0mm
    BUIL false
    PDNAME unset
    NEW FRMWORK /MDS/FT508/15-FRMW1
    BUIL false
    SHOP false
    GRADE 0
    FIRE 0
    PTSP unset
    INSC unset
    PDNAME unset
    NEW SCTN /MDS/FT508/15-BAR-1
    GTYP ANG
    DESP 1140
    BUIL false
    SHOP false
    DRNS E 45 U
    DRNE W 45 U
    POSS W 50.3mm S 16.5mm D 20.9mm
    POSE E 50.3mm S 16.5mm D 20.9mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    SPRE SPCOMPONENT /BS-SPEC/70x70x10.0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -20.9
    END
    NEW SCTN /MDS/FT508/15-V1
    PURP MITR
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 180degree
    DRNS U
    DRNE W 45 U
    POSS E 50.3mm S 16.2mm D 220.9mm
    POSE E 50.3mm S 16.2mm D 20.9mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -20.9
    END
    NEW SCTN /MDS/FT508/15-V2
    GTYP ANG
    DESP 1070
    BUIL false
    SHOP false
    BANG 90degree
    DRNS U
    DRNE E 45 U
    POSS W 50.3mm S 16.5mm D 220.9mm
    POSE W 50.3mm S 16.5mm D 20.9mm
    JLIN NA
    JUSL NA
    CTYS NULL
    CTYE NULL
    GRADE 0
    FIRE 0
    MEML NA
    :MDSOlap 'OVERLAP'
    :MDSOnum -20.9
    END
    END
    END
    END
    OLD SCTN /MDS/FT508/1-BAR-1
    MATR SOLID /CARBON/STEEL
    OLD SCTN /MDS/FT508/1-V1
    OLD SCTN /MDS/FT508/1-V2
    OLD SCTN /MDS/FT508/2-BAR-1
    OLD SCTN /MDS/FT508/2-V1
    OLD SCTN /MDS/FT508/2-V2
    OLD SCTN /MDS/FT508/3-BAR-1
    OLD SCTN /MDS/FT508/3-V1
    OLD SCTN /MDS/FT508/3-V2
    OLD SCTN /MDS/FT508/4-BAR-1
    OLD SCTN /MDS/FT508/4-V1
    OLD SCTN /MDS/FT508/4-V2
    OLD SCTN /MDS/FT508/5-BAR-1
    JOIS SJOINT /MDS/FT508/5-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/5-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/5-V1
    OLD SJOINT /MDS/FT508/5-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/5-BAR-1  END
    OLD SCTN /MDS/FT508/5-V2
    OLD SJOINT /MDS/FT508/5-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/5-BAR-1  START
    OLD SCTN /MDS/FT508/6-BAR-1
    JOIS SJOINT /MDS/FT508/6-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/6-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/6-V1
    OLD SJOINT /MDS/FT508/6-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/6-BAR-1  END
    OLD SCTN /MDS/FT508/6-V2
    OLD SJOINT /MDS/FT508/6-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/6-BAR-1  START
    OLD SCTN /MDS/FT508/7-BAR-1
    JOIS SJOINT /MDS/FT508/7-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/7-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/7-V1
    OLD SJOINT /MDS/FT508/7-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/7-BAR-1  END
    OLD SCTN /MDS/FT508/7-V2
    OLD SJOINT /MDS/FT508/7-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/7-BAR-1  START
    OLD SCTN /MDS/FT508/8-BAR-1
    JOIS SJOINT /MDS/FT508/8-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/8-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/8-V1
    OLD SJOINT /MDS/FT508/8-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/8-BAR-1  END
    OLD SCTN /MDS/FT508/8-V2
    OLD SJOINT /MDS/FT508/8-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/8-BAR-1  START
    OLD SCTN /MDS/FT508/9-BAR-1
    JOIS SJOINT /MDS/FT508/9-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/9-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/9-V1
    OLD SJOINT /MDS/FT508/9-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/9-BAR-1  END
    OLD SCTN /MDS/FT508/9-V2
    OLD SJOINT /MDS/FT508/9-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/9-BAR-1  START
    OLD SCTN /MDS/FT508/10-BAR-1
    JOIS SJOINT /MDS/FT508/10-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/10-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/10-V1
    OLD SJOINT /MDS/FT508/10-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/10-BAR-1  END
    OLD SCTN /MDS/FT508/10-V2
    OLD SJOINT /MDS/FT508/10-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/10-BAR-1  START
    OLD SCTN /MDS/FT508/11-BAR-1
    JOIS SJOINT /MDS/FT508/11-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/11-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/11-V1
    OLD SJOINT /MDS/FT508/11-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/11-BAR-1  END
    OLD SCTN /MDS/FT508/11-V2
    OLD SJOINT /MDS/FT508/11-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/11-BAR-1  START
    OLD SCTN /MDS/FT508/12-BAR-1
    JOIS SJOINT /MDS/FT508/12-V2/S1/IJOINT1
    JOIE SJOINT /MDS/FT508/12-V1/S1/IJOINT1
    OLD SCTN /MDS/FT508/12-V1
    OLD SJOINT /MDS/FT508/12-V1/S1/IJOINT1
    CREF SCTN /MDS/FT508/12-BAR-1  END
    OLD SCTN /MDS/FT508/12-V2
    OLD SJOINT /MDS/FT508/12-V2/S1/IJOINT1
    CREF SCTN /MDS/FT508/12-BAR-1  START
    OLD SCTN /MDS/FT508/13-BAR-1
    OLD SCTN /MDS/FT508/13-V1
    OLD SCTN /MDS/FT508/13-V2
    OLD SCTN /MDS/FT508/14-BAR-1
    OLD SCTN /MDS/FT508/14-V1
    OLD SCTN /MDS/FT508/14-V2
    OLD SCTN /MDS/FT508/15-BAR-1
    OLD SCTN /MDS/FT508/15-V1
    OLD SCTN /MDS/FT508/15-V2
    INPUT END  ZONE /MDS/FRAMES/FT508
    INPUT FINISH
    -- Switch synonyms back on if an error occurs.
    LABEL /ERROR3
    handle ANY
    $S+
    RETURN ERROR
    endhandle
    -- End Data Listing    Date : 27 Feb 2020 12:21
    $S+  -- Synonym translation ON
  • hi
    Send your personal id i will send files, unable to upload here
    thank you
  • [email]suryapiping@gmail.com[/email]
    Suryapiping at gmail dot com
  • [QUOTE=lsurya;115330][EMAIL="suryapiping@gmail.com"]suryapiping@gmail.com[/EMAIL]
    - - - Updated - - -
    sent,  please check
