Pipe Support(MDS) MDS Supports AutoNaming
  • Replies 10 replies
  • Subscribers 3 subscribers
  • Views 174 views
Private
Private over 5 years ago
  • Private
  • Tejas Desai
    Tejas Desai over 5 years ago
    Dear Prossly use following  for  pipe
    Prefix \ NAMN OF PIPE OF CompRefe OF ANCI1 OF SUPC1
    Index \ 1
    Suffix \
    IWidth \ 3
    regards,
    Tejas
  • Aurelio Hinampas
    Aurelio Hinampas over 5 years ago
    MDSAUTONAME form code does read variable declaration as what you intend to do and doesn't accept spaces in between also. It will just look for the keyword PREFIX, INDEX & so on then get the value after \. ZONE name is possible as shown below but for the PIPE, I'm not sure or can't be at all unless you modified the MDSAUTONAME macro that will suits your requirements.
    Prefix \$!!mdsOptions.site.val
    Index \ 89
    Suffix \
    IWidth \ 4
    MinIndex \ 0
    MaxIndex \ 9999
    Why would you need the PIPE name for the Support Name? By practice, you should assign the all pipe support ZONE to the specific Support Naming File in the attribute :MDSAUTOFILE.
  • Private
    [QUOTE=Tejas;113158]Dear Prossly use following  for  pipe
    regards,
    Tejas
    Thanks so much Tejas, it's working right now.
  • Tejas Desai
    Tejas Desai over 4 years ago
    what is you requirement [COLOR=#417394]ESH_PDMS  [/COLOR]Please let us know your requirements.
  • Joy PA
    Joy PA over 4 years ago
    Dear Tejas,
    how to call the  [COLOR=#333333]ATTRIB PROP RNAME in the support name. Can you please advice..[/COLOR]
  • Robert D Anderson
    Robert D Anderson over 4 years ago
    I would like to use support attribute "Dtxrtext" as the prefix. Does anyone know what the syntax would be?
    please help on how to activate mds in paragon
    We are talking about something else here....
    Could you please open a new thread?
  • jeremiah udeme
    jeremiah udeme over 4 years ago
  • Aurelio Hinampas
    Aurelio Hinampas over 4 years ago
    Have you already found the answer for this query and which version are you using, PDMS or E3D?
