Pipe Support(MDS) Replace bulk MDS support..
  • Replies 4 replies
  • Subscribers 3 subscribers
  • Views 54 views
mEhul_patel
mEhul_patel over 4 years ago
  • mEhul_patel
    Dear Folks,
    i had placed MDS support In my area, now some support are changes, its ~3000 qty.
    now i want change all old support to new updated type support.
    is it possible???
    my both support in same ANCI group. I have already try to change spref as per new support, but graphic is not came properly.
    kindly suggest me what we can do.
    Thanks,
  • Aurelio Hinampas
    Aurelio Hinampas over 4 years ago
    You may refer for the solution with this similar issue on the other existing post.
    https://www.avevaworldforum.com/showthread.php?21818-Updating-Pipe-Supports
  • mEhul_patel
    [QUOTE=rhel;118053]You may refer for the solution with this similar issue on the other existing post.
    Thanks Mr. rhel, i have already read this post before send.,
    but i will not used for my entire project, because i have change many other support properties, which i don't want to  change.
    so, if have use same code for all support, it is impact other support properties also.
    i want change particular ANCI support (limited size),.
    it would really be great of great use to me if possible.
    thanks for reply,
    Regards,
    MP
  • Anna Bauman
    Anna Bauman over 4 years ago
    Just move the once you need changed into a separate ZONE and run the macro on that ZONE alone
