Any workaround for using 2 Standard Framework Design Template Databases for Support Modelling in a single project ?
We can use one out of the available AISC, DIN, and BS Template Databases. Even if we put 2 databases in MDB, the one on top of DB List of that MDB will be reflected in Create Framework MDS Form.
One solution that I have tried is Merging both in one DB by using DB-Listing of both DBs and renaming the template serial numbers in one of the DB so as to ensure no conflict in names.
However I am looking for a better workaround to handle this requirement. Any suggestions or solutions available ?
