I am new in MDS Support and still learning the process.
I want to create new Support Framework not in AVEVA Default Frameworks. May i know what macros are needed to prepare before the creation? Also, what will be the basis of the position of zone when creating the framework template?
Additional Information, base on my initial investigation, I need to add the new Support Framework in mdsCreateFT function and need to create new object i.e mdscreateftfourteen.pmlobj . Is there other macros to add or update?
Additional question, is there an attribute that is stored to connect the set Frameworks in Paragon that will ling to the Framework Template in design?
