Specon Module Specon Manual
  • Replies 36 replies
  • Subscribers 3 subscribers
  • Views 89 views
Specon Manual
rxk
rxk over 18 years ago
  • Srinivas Vinjamuri
    Srinivas Vinjamuri over 15 years ago
    Shrikanth,
    I did not get you clearly, are you asking about "SITE" where it is locates in project folder?
    Srinivas
  • avwf_shrikanth480850
    avwf_shrikanth480850 over 15 years ago
    Srinivas,
    yes....and how to open it directly without opening it from design explorer......
    srikanth
    Shrikanth,
    I feel you are in starting stage on PDMS, You can not find the site in the project folder. Please read the manuals. So you can get the information how PDMS stores the data.
    Thanks,
    Srinivas
  • avwf_Stefan945996
    avwf_Stefan945996 over 15 years ago
    Hi,
    I was reading the above information and have a question
    When i output the spec file on the longer lines the text is cut with a $ sign and passed on to the next line.
    Is it possible to avoit that?
    if I remove all the $ signs and input the file will there be any problems with the system to accept it?
    Thanks,
    Stefan
  • Raymond Metselaar
    Raymond Metselaar over 15 years ago
    I think that the $ sign was for making the file 'readable' so that would cut it off at 80 characters. Now I think it should not be a problem now but I have not tried it out. The longest PDMS line can read in is 256 characters and then it will stop reading the line.
    Hth,
  • Abba-Gana, Abubakar
    Abba-Gana, Abubakar over 15 years ago
    we are are using 11.6 and we still have that problem.
    Stefan, you can remove the dollar and realign before running it in. it works this way.
  • avwf_Stefan945996
    Thanks abba,
    I will try.
    Regards,
    Stefan
  • john pitchers
    john pitchers over 15 years ago
    There is a useful little tool posted in this thread
    http://www.pdmsworld.com/forum/specon-module/696-no-more-specon.html
  • Raymond Metselaar
    Raymond Metselaar over 14 years ago
    [QUOTE=pitch;42151]There is a useful little tool posted in this thread
    http://www.pdmsworld.com/forum/f12/no-more-specon-696.html
    Url has changed into above one
  • Cody Austin
    Cody Austin over 14 years ago
    There is an option to not have it "wrap" things onto a new line.  I forget what the command is.  I will get back to you in the morning.
