Specon Module Spec Heading
  • Replies 12 replies
  • Subscribers 3 subscribers
  • Views 27 views
Spec Heading
Mohamed Naseh
Mohamed Naseh over 17 years ago
  • Mohamed Naseh
    I make a new spec with and I put in it new catalouges which I made before .. and now I make a text file to create a new spec to put in specon .. so the heading of this spec is consist of ( Type Name PBOR SHOP ........)
    Now , I want to know What Name is depending on .. and how can I put the Name of the components ??
  • Abba-Gana, Abubakar
    Abba-Gana, Abubakar over 17 years ago
    Component name can be any alphanumeric combination, if you like you can derive the name from catref size eg */AAEA200:250 etc, if you like you can call it /*ELBOW45:250 and so on. */ is a default representing the spec name.
    I hope I understood your question.
    abba
  • Mohamed Naseh
    Thanks Abba .. I got it .. but I want to ask you a question in heading also ..
    When I creat a new spec.txt and filling the Stype column .. How many characters does Specon agree ?
    I do not know the maximum but I have use between two and four severally.
  • john pitchers
    john pitchers over 17 years ago
    Maximum 4 alpha characters ( no numbers)  eg FLAN  ELBW
    if this is not enough you can use TEXT in the STYP column instead.
    eg TEXT  'EL90'
        TEXT 'PSV-1234A'
  • Mohamed Naseh
    Thanks guys for this great information :D
  • Mohamed Naseh
    Another question plz .. What's the meaning of this error "DITTO IN FIRST LINE" ??
    I've read it in the manual but I didn't understand what can I do to avoid it ??
  • Abbas Ali
    Abbas Ali over 17 years ago
    + sign is used as ditto....i.e if u wanna use value of the previous item witout typing or copying the whole string...you can use + sign as ditto.....e.g.
    */ASEC2:250   250   ELBN    /ASEC200  /ASEC200-D  =0  =0
    */ASEC2:350   350    +       /ASEC211  /ASEC200-D  =0  =0
    */ASEC2:450   450    +      /ASEC244  /ASEC200-D  =0  =0
    Now I believe in ur case you have used the ditto (+) sign in the first row and that is logically not allowed.....ditto sign should always go under an existing value ...
    Hope this helps...
  • Mohamed Naseh
    Mohamed Naseh over 15 years ago
    Question Please,
    If I have 3 way valve "Multiway Valve" that contains 3 flanges different in PBOR so, what is the suitable heading ??
  • Mohamed Naseh
    Thanks I've solved it :)
