    $S-
    $(  BORE UNITS MM    $)
    $(  DISTANCE UNITS MM    $)
    OLD SPECIFICATION /ABC-TRAINING
    VERSION 1151
    MATREF =0
    FLUREF =0
    RATING 0.000
    LINETYPE NULL
    BSPEC =0
    TEXT 'PIPING'
    HEADING
    TYPE     NAME             PBORE    STYP    SHOP     CATREF       DETAIL           MATXT    CMPREF    BLTREF
    DEFAULTS
    -        -                -        P       -
    TUBE     */PIPE-25        25       P       TRUE     /PIPEBE-25   /PIPEBE-DTXT     =0       =0        =0
    HEADING
    TYPE     NAME             PBOR1    PBOR2    STYP    ANGL    SHOP     CATREF                     DETAIL           MATXT    CMPREF    BLTREF
    DEFAULTS
       -     -                -        -        NTY     90.00   -
    ELBO     */E90LRBWBW-25   25.00    25.00    NTY     90.00   TRUE     /E90LRBWBW-25-25-TRAINING /E90LRBWBW-DTXT   =0       =0        =0
    HEADING
    TYPE     NAME             PBOR1    PBOR3    STYP    SHOP     CATREF                     DETAIL           MATXT    CMPREF    BLTREF
    DEFAULTS
    -        -                -        -        TEEE    -
    TEE      */TEEEBWBW-25    25       25       TEEE    TRUE     /TEEEBWBW0-25-25           =0               =0       =0        =0
    HEADING
    TYPE     NAME             PBOR1    PBOR2    STYP    SHOP     CATREF                     DETAIL           MATXT    CMPREF    BLTREF
    DEFAULTS
    -        -                -        -        REDC    -
    REDU     */REDCBWBW-65-25 65       25       REDC    TRUE     /REDCBWBW0-65-25           =0               =0       =0        =0
    HEADING
    TYPE     NAME             PBOR1    PBOR2    STYP    RATI    SHOP     CATREF                     DETAIL           MATXT    CMPREF    BLTREF
    DEFAULTS
    -        -                -        -        FL      -       -
    FLAN     */FLAWNRF-25     25       25       FL      150     TRUE     /FLAWNRFA-25-25            =0               =0       =0        =0
    FLAN     */FLASORF-25     25       25       SO      150     TRUE     /FLASORFA-25-25            =0               =0       =0        =0
    $S+
  • In Header for pipe (line 16 )  write  PBOR0  instead of PBORE.
    Thsi should help you rest of the fiel looks okay .
  • Thanks "tbr".
    Now the error moved on to Line 26 "Spcom name /ABC-TRAINING/E90LRBWBW-25 already exists. New Spcom Rejected."
    This elbow was previously there in old spec.
    Can you please suggest me how to attach my specon error to this thread :(
  • take a snap shot ctrl+printscreen  ,paste it in mspaint and send.
    if the elbow is alread existing then y do u need another one for same size?
  • I forgot to mention that i am new to Specon, so i have no idea how to modify the spec. So do u mean no need to run this elbo again? do u want me to delete this elbo from ABC-TRAINING.TXT and run it again in Specon?
    I need this Elbow remains avilable in Design in same spec.
  • Thanks a lot dear, the spec run was successful. Now i will move on to Bolting, i heard that bolting is going to be a bit of tuff task to do :P
  • @fazuluddin,
    next time when outputting spec for editing you can use this synthax. output new /xxxx. so that you do not need to swap name and stype. this will save alot of hours for you.
  • Thanks a lot "Abba", i will try your suggested command now onwards.
