Specon Module Adding New Spec
  • Replies 8 replies
  • Subscribers 3 subscribers
  • Views 9 views
Adding New Spec
Brian Dodge
Brian Dodge over 15 years ago
  • Brian Dodge
    Hi All,
    2 questions:
    1. When adding a spec in specon, is there a level in SPWLD that I should be on that will allow me to add the new spec so that it appears where I want it when viewed in DESIGN (alphabetically)?
    example: Spec A, B & D exist.
    When adding C how do I put it between B & D?
    My new specs are appearing at the top of my list in DESIGN.
    2. I've added a new spec "N" at the SPWLD level.
    It appears at the top of my list in DESIGN. I want to move it between M & O.
    Is there a way to modify the hierarchy after the spec has been added?
    Thanks
  • Brian Dodge
    Found it.
    I just wasn't in the right location when I added the new spec.
  • john pitchers
    john pitchers over 15 years ago
    You can always go back to the specworld later in PARAGON and reorder them
    Orlando de Oliveira Amaral dos Santos over 15 years ago
    Hi Acadman!!
    pitch´s answer is the best way to do it...
    By the way, what company do you work for ? Is it in Canada? I´m asking you because I´m moving to Quebec.
    Tks
  • avwf_varun424871
    avwf_varun424871 over 15 years ago
    How can i add a component to pipe component spec list.
  • john pitchers
    If you are a "designer" then you ask your Cats & Specs guy. He will check that it conforms with the written pipe spec and add it if it is allowed.
    If you are a Cats & Specs user, and you do not know the answer to this question, then you shouldn't be.
  • Alberto Dela Cruz
    Alberto Dela Cruz over 15 years ago
    hi, how to enter the specon of SAM project in PDMS? I input
    Project: SAM
    Username: SYSTEM
    Password: xxxxxx
    MDB:
    module: specon
  • Juan Manuel Gutierrez Valderrama
    Juan Manuel Gutierrez Valderrama over 15 years ago
    [QUOTE=herculez1980;38414]hi, how to enter the specon of SAM project in PDMS? I input
    Project: SAM
    Username: SYSTEM
    Password: xxxxxx
    MDB:
    module: specon
    Select the MDB: PIPE
