Hello guys...
I have a doubt since a bit of time ...
As I studied the program all alone and by myself, so without following any trainings etc...
Can I ask you how do you do to compilate a piping spec in PDMS?
I mean... the steps to make it.. like, I do this:
-Open notepad and write the PDMS code for the next insertion in specon, so like this:
"/NEW.SPWL
NEW SPEC /NEW
TEXT 'PIPING'
HEADING
TYPE NAME PBOR0 SHOP STYP CATREF DETAIL
DEFAULTS
TUBE */AA000 15 TRUE TEXT 'AA000' /AAPA100DD /AA000D"
etc...etc...
Then with Paragon opened, i take the referring CATREF component... then I create the DETAIL one by one...
When I finished everything, I open SPECON and paste the entire notepad file in it for the specification .
That's all!
Is that right guys or s there a simplified method to create specifications???
Thaaaaanks!
First you have to create all the Catlogue components in Paragon.
Catref - Component reference
Detail text - Information about the component with SKEY
Cmpref - properties like weight density and all (If needed) - Please note this has to be created using Propcon module.
and Bolt references for Flanges and Flanged Components.
Then you have to run the specon file in the .txt format (Eg: xxx.txt , similar to the one you have) with the above references included and run it in Specon using the command.
$m XXX.txt
