You need to use the following syntax:
EXTRA :uda_name attribute_setting
You can read C:\AVEVA\Plant\PDMS12.0.SP6\Manuals\Docs\Catalogues and Specifications Reference Manual.pdf Chapter 12.3.7 Including User-defined Attributes in Specifications
Can somebody guide me how to add user defined HEADING under headings in specon???
My objective is to add a unique number to every spcom. For that I created an UDA named "MTNUM" as spco. I added the same under heading. but when I tried loading in spec, I got some error in specon. Could somebody pls help me to create the above specified?
My headings are like this,
HEADING
TYPE NAME PBOR0 STYP CATREF DETAIL MATXT CMPREF BLTREF MTNUM.
Many Thanks Gentle man.... As u said I read the Manual before posting the question. But I'm confused with the syntax. Now it's clear.... Many thanks once again.
[QUOTE=corrado;61138]You need to use the following syntax:
