• Hi,
    I've been tasked to look at a OD Tubing pipe spec this week.
    All was going fine until I had the bombshell dropped on me that it had to include NB pipe as well.
    The project wants to use Imperial Pipe sizes and Metric OD tubing
    And obviously (and awkwardly) I've also got 25mm OD Tube jostling with 1" NB Pipe and 12mm OD Tube nestling alongside 1/2" NB Pipe.
    Now this raises two issues for me.
    Whats the best way of segregating these properly, because as it stands the Design will try and connect tube right up to the appropriate NB pipe fitting (which is wrong).
    Secondly, how do I add tube sizes (can I? Should I?) to the size tables?
    Thanks for your thoughts in advance.
