How to Cancel the default selection?
  • [QUOTE=Paulobod;62759]thanks for the reply. The STYP is different, for safety valv (PSV), and for control valve (CNTRL).
    this is the order...
    TYPE  NAME               PBOR0 PBOR3   SHOP STYP        CATREF         DETAIL             MATXT CMPREF BLTREF
    DEFAULTS
    INST */PSV50X25-900 25 50     FALSE PSV        /PSV50X25-900 /SDPSV50X25-900 =0 =0 =0
    INST */ICNTRL50900 50 50     FALSE CNTRL /CNTRL50900 /S.CNTRL-900        =0 =0 =0
    What is wrong in this???
    Have you solved your problem? If your answer is no then try the following
    The stype normally accepts four charters only try to change [COLOR="red"]CNTRL [/COLOR]to [COLOR="red"]CNTR [/COLOR]or else if you really need to have more than four charters you can use [COLOR="red"]TEXT 'CNTRL' [/COLOR] instead of just CNTRL
  • [QUOTE=williams.richardson;62789]Have you solved your problem? If your answer is no then try the following
    Many Thanks bro
  • [QUOTE=pitch;62786]you should not use pbor0 with a second bore. It should be used alone.
    Pbor0 checks pbor1 first for a match then pbor2 if pbor1 does not match.
    In your header you should use TYPE NAME PBOR1 PBOR2
    Thanks for all your information pitch... let me try with ur suggestion... take care..
  • Catview is probably good for 11.6 and lower (even though I have used my own tools) but for 12 it is built in function to create specs much comfortable
  • I do that with CATVIEW.
    Open CATVIEW, go to Modify/specification
    In the form select the component and in the window Selected Items select Reorder as default
    CATVIEW is a good complement of PARAGON, I wonder why some people want to stop the development.
    For many tasks is better and quicklier than PARAGON
  • Yes, after the version 12 I made meinly the SPECS with CATVIEW, but I still use CATVIEW for reorder as default, for insert some componets because gives the name of the SPCO including the diameter, with PARAGON gives the name of the SPCO as ELBOW/1 , ELBOW/2, it's not clear. Yes you can use autonaming but it doesn't run for all the components ( it's part of other post).
    I use also CATVIEW for search componets ( categories) more quickly than with PARAGON, because you can filter easily by TYPE and by STANDARDS ( Din, ANSI, or customized). Search is very powerful but it takes more time.
    I wonder that CATVIEW continue for a long time until PARAGON can manage better the components.
