Specon Module
How to Cancel the default selection?
3 subscribers
paulo
over 13 years ago
Corrado Galluzzi
over 13 years ago
Are you using PDMS12?
Anyway check their STYP selector.
It has to be different.
paulo
over 13 years ago
Dear all,
I've loaded safety valve and control valve under instrument (GTYP INST). When I select a control valve it selects safety valve by default. How to change the selection???
paulo
over 13 years ago
[QUOTE=corrado;62754]Are you using PDMS12?
thanks for the reply. The STYP is different, for safety valv (PSV), and for control valve (CNTRL).
this is the order...
TYPE NAME PBOR0 PBOR3 SHOP STYP CATREF DETAIL MATXT CMPREF BLTREF
DEFAULTS
INST */PSV50X25-900 25 50 FALSE PSV /PSV50X25-900 /SDPSV50X25-900 =0 =0 =0
INST */ICNTRL50900 50 50 FALSE CNTRL /CNTRL50900 /S.CNTRL-900 =0 =0 =0
What is wrong in this???
Mohamed Naseh
over 13 years ago
have you checked the default mark in the create component menu ?
Corrado Galluzzi
over 13 years ago
Do you really need to have a PBOR3 selector for your instruments?
paulo
over 13 years ago
yes bro, I un checked the option... is there anything wrong in my spec loading...????
Mohamed Naseh
over 13 years ago
check the current bore
Mohamed Naseh
over 13 years ago
if it is 25 the PSV will appear because the PBOR0 is 25 and if the bore is 50 the CNTRL will appear because the PBOR0 is 50
john pitchers
over 13 years ago
you should not use pbor0 with a second bore. It should be used alone.
Pbor0 checks pbor1 first for a match then pbor2 if pbor1 does not match.
In your header you should use TYPE NAME PBOR1 PBOR2
john pitchers
over 13 years ago
PBOR3 on PSV & CONTROL VALVES are not normally connection ppoints
