Specon Module Error (17,7)
  • Replies 5 replies
  • Subscribers 3 subscribers
  • Views 9 views
Error (17,7)
Pacha
Pacha over 13 years ago
  • Pacha
    Hi,
    I have performed some modifications to my specification then re-loaded it using $m.
    No problems up to the line 2040 and after...
    I receive the following message:
    (17,7) Answers select previously defined SELEC 12 of SELEC 8 of SPECIFICATION /M15A
    What I can not understand is what the SELEC is doing here?
    I could resolve -temporarily- the problem by removing (to Limbospec) the problematic SPCOs, but I guess this is not the best solution.
    Any help, please, to understand the problem?
    Thanks
  • Mohamed Naseh
    Mohamed Naseh over 13 years ago
    I think there is a duplication in the STYPE or SPCO name so you have to change it and rerun it again.
  • Pacha
    Unfortunately, no; I have checked line by line and there is no duplication.
    Each SPCO has its proper name...
  • ANTONIO RETAMERO
    ANTONIO RETAMERO over 13 years ago
    It is not a problem of name.
    The point is that the different SELECs should lead to one unique SPCO and this is not the case in your SPEC. Check this line and the rest of the SPEC again.
  • Mohamed Naseh
    [QUOTE=pacha2003;66185]Unfortunately, no; I have checked line by line and there is no duplication.
    Could you please send me the SPEC text file ?
