that was thinking!
but how can i solve this?! i'm trying execute just the command isodraftmode and the command but my custon not working and removed the command "tubefactor 1".
have you any idea?
Regards
Quando removi o codigo "tubefactor 1" o peso do tubo ficou menor o mesmo comprimento do tubo do mesmo isometrico na versão anterior.
ele gerou o isometrico mas o tubo ficou "errado".
I check isodraft and spooler configuration both have the same elements. What change between them its the width . spooler Column 7 OTHER Heading 'PESO' WEIG with Width 11 Total Fabrication Total Erection Total Combined Factor 1 isodraft Column 6 OTHER Heading 'PESO' WEIG with Width 7 Total Fabrication Total Erection Total Combined Factor 1
and i discorver that the weight of one valv is not computing.
