When am error occurs in specon like no of columns are mismatch or default values are more etc.
aim unable to perform any command like term,specon,own,finish,quit, etc...
if i re-enter to specon or swaping from other module,it opening in monitor module..
Console Message as follows
(43,41) Unable to open DB MASTER/PROP, FIU:File in use
ERROR CONDITION OCCURRED WHILST MODULE SWITCHING
(41,55) No databases to work from.
In line 272 of Macro C:\AVEVA\plant\PDMS12.0.SP5\pmllib/limbo/functions/modulesw
itch.pmlfnc
$!nextModule.command $!readOnly
Called from line 59 of Macro C:\AVEVA\plant\PDMS12.0.SP5\pmllib/monitor/function
s/pdmsloginok.pmlfnc
Specon is stuck somewhere in the defaults line.
Typing QUIT etc gets (47,15) CP: Syntax error message
To continue you need to complete the defaults line.
Try typing a minus sign (-) and return
If you get the * prompt you are done and continue with normal Specon commands
If you get (47,62) CP: Incomplete command line Message
Try typing two minus signs (- -) and return
I usually find that 2 minuses are enough. if not then repeat (with an extra minus each time) until the * prompt appears.
