Backtrack changes do not recover prior situation
  • Hello
    I'm working with PDMS 12.1. I was doing some tests with small DN elbows (DN < 2"), and for accident, I wrote over the existing spec. It was a whole spec with DN until 24" (at least). After I wrote over it became a spec only with elbows and DN < 2". So I went do Admin and did a backtrack changes to the last session of the catalog DB. From this point on things became weird.
    If I open paragon all the SPCO appear in the hierarchy. But if I try to take spec out through Specon or Paragon (Modify -> Specification) the file is empty.
    In Design, the itens that were modelled before, they are all there, with spref and ref (even if I get out from design and enter again). But if I try to create nem components the only options are DN 1/2" to 1.1/2" elbows
    I backtrack changes with prior sessions some times and also expunged all the users from the project but nothing seams to help
    Did someone already faced something like this? No idea how to handle it.
    Thanks in advance
  • Solution found. I don't konw if this happens for security reason but the spec was not over written. PDMS created a new one, with the same name, in the limbo from another DB. This took me a while to find.
