Specon Module Bolting method OLD and NEW
  • Replies 6 replies
  • Subscribers 3 subscribers
  • Views 65 views
karthikeyan
karthikeyan over 11 years ago
  • karthikeyan
    Hi
    Can anyone help me out with the difference in OLD and NEW bolting methods.
    Or the links that explains the difference in the bolting methods
    Thank you
  • PATHI SATHISH KUMAR
    PATHI SATHISH KUMAR over 11 years ago
    Dear Friend,
    In old bolting method you need to give bolt reference to every spco.
    And you need give standard bolt length and extra length also, in SBOLT.
    But in new bolting method you need to give blrfarray reference in catalogue. and flange thickness need to be set as RPRO Attribute( FLTH).
    And you need to create new bolt spec.
    In piping spec you need to set bolting method as new and set bolting spec( bolt spec name).
    In new bolting method only extra bolt length is enough. In this method it will call the thickness of flange or fit length of wafer components and it adds extra length which you have given in sbolt, after that it will check the nearest value in bolt length table and it will populate in isometric.
  • john pitchers
    john pitchers over 11 years ago
    Flange thickness does not [COLOR=#0000ff]NEED[/COLOR] to be set as RPRO Attribute( FLTH).
    That is just one of the options available.
    Using Datasets for bolt thickness can create a problem when allocating Bolts for items with different bolt requirements at each end, eg Relief Valves.
  • karthikeyan
    Thank you sathish and pitch.
    One more query is
    Is that BSEL value should be given design for all components
  • john pitchers
    You only need to set the BSEL in design when you do not want the default bolt to be used
  • karthikeyan
    thank you pitch
