Specon Module
error copying a spec
3 subscribers
Admin
over 10 years ago
Admin
over 10 years ago
Hello pdms’s guys
Pdms : 12.1.sp2
Aim : copy an existing spec
Problem : when I try to copy the existing spec with a macro like this :
“ $S-
$( BORE UNITS MM $)
$( DISTANCE UNITS MM $)
NEW SPECIFICATION /RBN/B01
VERSION 1212
MATREF =0
FLUREF =0
I got an error “ CP : Syntax error in line 6 ^^version 1212”
And the copy failed.
Any idea someone ? I have done this method with pdms version 11 and it was fine.
Thanks
Admin
over 10 years ago
yep corrado
correct : I was in paragon ... works better in specon
:encouragement:
thanks for quick reply
Corrado Galluzzi
over 10 years ago
Make sure you are running that macro in SPECON and not in PARAGON...
Vineet Bhardwaj
over 10 years ago
Check with version 1211
kamalakar sutar
over 10 years ago
Just type 'Speconmode' in paragon module if you are using PDMS 12 and run the macro
