Lessons Learned - Error Codes Section
  • One of our moderators JCont20 had an idea to start this new section named "Lessons Learned" and I really do not know why we never had it before. We talked today and decided to build a section specifically for Error codes and Troubleshooting so here it is.
    This is the reason we have moderators...These guys think of everything.
    Expert:bignerd:
  • it is an excellent work highly appriciated about this idea
    where will be list of errorcode and meaning
  • Basai, :brick:
    Would you please spend sometime read existing posts and probably PDMS manauls.
    Your questions are always welcome, but it is a lot of work for moderators to answer the same questions over and over again and try to clean up threads.  Unlike other forums we do not put restriction on new users/vistors and you do not have to respond to post before being able to read.
    So thank you, all the new users for visiting and contributing, but PLEASE RTFM first.
    PDMSworld would rather have 1,000 quality posts then 10,000 ones with repeated questions.
    And yes, we will be working on FAQ section for each forum when we have time.  So if anyone wants to scan the posts and compile a FAQ please let me know.
  • I´m always surprised that 70 % of the questions/answers are being taught in the basic training courses or in the special courses by AVEVA.
    Followed by the last bits that are in the thirtysomething manuals. Some of them could be better, i admit that, but a lot of them are fine and easy...accessable by EACH Aveva customer. It´s just reading ;-)
    sorry if this sound arrogant, but sometimes TO many low level questions can really take a forum down, so I totally agree with de_ding
    (like the classic in hardware forums: "Which PC would you recommend?"
  • Help me please, There's somebody saw error : (191,801)LMI  acquire license failed.
    error 191 is Cannot run %1 in Windows NT mode.
    801????
  • the 191 cannot run %1 in windows NT Mode is a microsoft error message
    In pdms 191 & 191 are laser module errors
    The list I have just repeats your original error message
    191,801 - LMI acquire licence failed
    So it appears you have a licence problem
    190 - LASER MODULE ERRORS
    190,1 - PTCL API Version
    190,2 - PTCL Driver Version
    190,3 - Maximum number of models
    190,4 - Maximum viewport width
    190,5 - Maximum viewport height
    190,6 - Front/back plane clipping
    190,7 - Maximum views
    190,8 - Maximum regions of interest
    190,9 - Maximum highlight regions
    190,10 - Maximum clip extrusions
    190,11 - Maximum clash volumes
    190,12 - Renderfast
    190,13 - LowResEverywhere
    190,14 - Volume test box
    190,15 - Volume test cylinder
    190,16 - Volume test sphere
    190,17 - Volume test oblique
    190,18 - Maximum view quality inside
    190,19 - Maximum view quality outside
    190,20 - LMI licence available
    190,21 - No LMI licence available
    190,22 - Viewport width
    190,23 - Viewport height
    190,24 - Background colour (R, G, B, A)
    190,25 - Front and back clipping distances
    190,26 - Front/back plane clipping ON
    190,27 - Front/back plane clipping OFF
    190,28 -  region(s) of interest
    190,29 -    Region of interest
    190,30 -  XLength
    190,31 -  YLength
    190,32 -  ZLength
    190,33 -  at
    190,34 -  highlighted region(s)
    190,35 -    Highlighted region
    190,36 -  colour (R, G, B, A)
    190,37 -  clash region(s)
    190,38 -    Clash region
    190,39 -  model(s)
    190,40 - Model
    190,41 -    Dabacon reference =
    190,42 -    Model ID
    190,43 -    Model string
    190,44 -    Driver connect string
    190,45 -    Model bounds
    190,46 - CE is not an XGEOM
    191 - LASER MODULE ERRORS
    191,1 - LMI/PTCL Failed
    191,2 - LMI/PTCL Function not supported
    191,3 - Maximum number unlimited
    191,4 - Vendor PTCL system out of resource
    191,101 - Invalid PTCL Connection String
    191,102 - Invalid PTCL User
    191,103 - Invalid PTCL Password
    191,104 - Invalid License For PTCL Server
    191,105 - Invalid PTCL Server Not Found
    191,106 - No PTCL Connection
    191,201 - Invalid PTCL Model ID
    191,202 - PTCL Model Not Found
    191,203 - Attempting to access too many PTCL models at any one time
    191,301 - Invalid PTCL ViewID
    191,401 - PTCL Volume Test Empty
    191,402 - PTCL Volume Test Occupied
    191,403 - PTCL Volume Test Unknown
    191,404 - PTCL Used Bounding Box
    191,501 - PTCL Ray Missed
    191,802 - LMI connect string empty
    191,803 - PTCL driver dll load failed
    191,804 - PTCL driver missing mandatory function(s)
    191,805 - PTCL driver dll not loaded
    191,806 - PTCL driver does not support the requested function or option
    191,807 - Model string empty
    191,896 - Invalid data returned from PTCL driver
    191,898 - Programming logic at fault (i.e. "this cannot happen")
    191,899 - Other LMI error
    191,900 - LMI Server error - #N
