Try deleting all of the user temp files in the %pdmsuser% location. When I get this error this is the first thing I do but, theywill need to setup ther desktop again. Does Anyone else have any ideas??
I've got the same error message, when I've tried to run DRAFT in our standard project (it's dbs are used as references for others projects).
The problem was in the directory hierarchy. This project has empty iso,mac,pic folders and after some cleaning we've delete these folders by mistake and mentioned error started to appear.
After creating empty folders iso,mac,pic everything is fine and Signal 11 is no more showed.
Unfortunately I think there are multiple cases where a Signal 11 trapped error can occur. I have it repeatedly on a model with clean Dice checks, and clean environment.
In my case I am exporting a model to DGN and there is an element(s) in a stru that causes it to happen. I can work around it by not exporting that particular stru. I have DB listed it out, deleted it and ran the DB listing back in and it still occurs.
I still have yet to find the offending element since there are hundreds in this particular stru. I will post once I find it.
[QUOTE=scottg;9893]In my case I am exporting a model to DGN and there is an element(s) in a stru that causes it to happen. I can work around it by not exporting that particular stru. I have DB listed it out, deleted it and ran the DB listing back in and it still occurs.
Please send the datal into support, if you can, and mention my name, and I may be able to identify it for you (and fix the bug that it triggers for the next release, whenever that is)
In my case I am exporting a model to DGN and there is an element(s) in a stru that causes it to happen...
If the "signal 11" goes away with the "HOLES OFF" setting, then I may already have solved the issue in the dev version (not yet released) but I would still be able to find the element triggering it.
We found this happened in Draft, sometimes it helped to move any section/cutting planes, holes off would also indicate that the Draft software is having graphical problems. Deleting and re-building wont change the cutting plane that maybe slicing something it cant handle, sometimes as little as 1mm will help.
