• Hi all,
    I have a created a cross with olet in paragon with 6 connection points.
    In design I connected all branches in the cross through multiway connection type. When a generated ISODRAFT in the design , it shows this error - 33:185
    Pls find the attached file to understand more about these issues. Solution with the earliest will be appreciable.
    Regards
    Sendhilkumar
  • there are limitation in using cross.  max 4 connection points.  You should strip off the P5 & P6, and let the item be as a corss with 4 connections.  Set the CROSS MTOR with the OLET reference, this case there should be 2, so that the material list will show up the items (2 weldolets).  Set 2 ATTAs on the CROSS to indicate that these are connected to the it.  On the connecting BRAN to the CROSS, you should not have a refrence on the CROSS else it will fail.  Have another ATTA on these connecting BRANs indicating that they are connected to the CROSS.
    If you can set a sketch on the ISO to indicate the detail of the CROSS.
    Wish you success.
    Nerdy..
  • A cross is only allowed 4 conection points
    Try redefining your scom with a gtyp of SHU (standard hook up) instead of CROS
    You will also have to place it in the spec and design  as a SHU also.
    SHU elements are allowed up to 10 connection points
