PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Error Codes Routing Error
  • Replies 4 replies
  • Views 10 views
Routing Error
Ohwofa
Ohwofa over 15 years ago
  • Ohwofa
    I tried to do my pipe routing.I tried to put a gasket and flange in my nozzle and i get this error message
    (Incompatible Connection types item Positioned with a 41N spool length from the previous component) i have tried severally no solutions can somebody please tell me what is the problem
  • Cody Austin
    Cody Austin over 15 years ago
    Is you nozzle and the gasket the same spec?  Check your COCO table.
  • john pitchers
    john pitchers over 15 years ago
    You should connect the branch head/tail to the nozzle and the gasket to the head/tail
    You cannot connect a component directly to equipment.
  • Thiago Trigo
    Thiago Trigo over 15 years ago
    Check if your flange and gasket share the same pressure rating.
