PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Error Codes Require Help on Dabacon Error 529
  • Replies 9 replies
  • Views 18 views
PRASHANT PRAKASH UPARKAR
PRASHANT PRAKASH UPARKAR over 15 years ago
  • PRASHANT PRAKASH UPARKAR
    Does anyone have solution for Dabacon error 529?
  • Shrivallabha Sharad Redij
    Shrivallabha Sharad Redij over 15 years ago
    Hi Prashant, looked up the error codes and found:
    529  'Table entry already exists'
    If that is of any help?
    Yes i saw that in the error list.....but needs a solution on this..... Reconfig doesnt help in this case. Because of this error the database almost behaves as a readonly database.....nothing can be created in it......Have hit a road block.....Does anyone have an idea what to do in such a situation.....
  • Poonkadir Boopathy
    Poonkadir Boopathy over 15 years ago
    Hi,
    I too had faced the same problem, i had expunged one user who claims some elements from a databse 2555 and then i want to copy the same Design DB with the same DBNO 2555 from a a foreign project, then i deleted the DB from Admin and copied the DB from foreign project. i could not copy. i got the same error 526, then i deleted the DB by opening the folder and then i deleted the DB manually and i copied the DB from ADMIN module.
    check for the DB which is having problem, please state the action you had made to get this error.
    P-5834
    Dabacon error 529 is displayed when importing Users with the same name as Teams from excel file.
    Thanks to everyone......The issue is now resolved. I reconfigured the DB again.....As per my assumption the reconfig removes all the errors in a database.....but i was wrong......i did a dice check on the extract database in the shadow project after recongfiguring it......There was a bucket error which was removed on dice check patch on option.......
  • kenzo flower
    kenzo flower over 14 years ago
    can you teach me how to do this?? i encountered the same error but im not familiar with reconfiguring the database. thanks!
  • Naresh Tarani
    Naresh Tarani over 14 years ago
    Read the Admin command Refernce Manual
    Regards,
    Naresh Tarani
  • Raymond Metselaar
    Raymond Metselaar over 14 years ago
    did you a DICE check with patch on first?
