[QUOTE=Shrivallabha;51021]Corrado, thank you for your input and insight. I guess those were the maximum runtimes we had in design module on the only PDMS project we had if my memory serves right. You have also marked this on another thread as a possible reason to give stackoverflow error.
Soon, we will be having a new project on v12 (yet to start). Personally, I do not have any Cats & Specs experience. Will it be wise then to make this part an action item that Cats & Spec guy will have to perform at the end of any spec update (as good practice kind of stuff)?
I had this problem with just very few customers. It doesn't happen regularly.
Depending an the way you create/modify piping specs, you could have empty SELEs.
But this doesn't necessarily mean that you will get that stackoverflow error.
Probably you get it with some particular Service Pack or Fix.
[QUOTE=corrado;51115]I had this problem with just very few customers. It doesn't happen regularly.
hi... Corrado
what are the possible causes for the stackflow error.
Now cleaned up my SPECs (Header of ATTAs have been differing). --> same result
Installed 11.6.5.30 --> same result
DICE results are OK.
I created a new project, copied the 5 DBs from the old (CATA(SPEC) - 3x DESI - PADD). --> same result
Now I know CATA or DESI is fighting me - but how to know who it is - or what?
