PDMS "Lessons Learned"
Error Codes
data base error 10
data base error 10
Venkata Rao Peta
over 13 years ago
Venkata Rao Peta
over 13 years ago
while doing clash checking the problem is occuring the model is little bit huge once he starts the clash checking in between the problem is occuring
in cosole database error 10
exited is coming
Ilgiz Kalimullin
over 13 years ago
database error 10 - 'Invalid external reference'
Are you pdms admin?
Matt de los Angeles
over 10 years ago
Hi, how to check and fix this error database error 10?
Thank you.
MOHAMED AUSWATH KHAN Z
over 10 years ago
Hi All,
Do we have a solution for this . I have the same error while extracting iso of a single pipe.
My dice check is well and good enough for both DB and Pipe.
Any one has the answer to solve please help on this
Pedro Valadares
over 10 years ago
Run dice with patch on checked.
If this does not work use the reconfigure command.
