how many different applications can we open at one time with 1 license on a particular license server. For example workstation A opens a design module while workstation B opens a paragon module. Is this possible or it must be at the same workstation to open severals applications with 1 license.
Every module of PDMS takes a license. You can only share the same license between modules opened on the same workstation.
Every workstation will take a new license even if you work in different modules. That is the way PDMS and other applications using Flexlm work.
