You might have to check the registry. I encountered problems when I had earlier versions of PDMS12 installed.
If there are some ghosts hanging around then you'll have to get rid of them.
Your user needs to be in "Administrator" category. This can be done by setting it Control Panel >> User Acounts >> Your User and then set it to computer Administrator. Most probably, the IT person will be able to do it for you if you can't by yourself.
this is ram, in my office the IT people are installed the pdms-12, in one machine. but i cant run the pdms, it showing the error message, i here with attaching the error message for your reference, kindly help me guys, where i have to go. this is very urgent.
awaiting for your reply
thanks in advance.
with rgds,
ram.[/COLOR]:unsure: :unsure: :unsure:
Might be wrong here... But look at you paths that are echoed back...
Most of the paths are showing 2 "\\" characters, instead of one. Looks like when you are defining the evars, perhas you are putting in an extra "\"...
Can you tell me onething right now we dont have administrator in my company, recruiting they are recruting admin person, and i have one doubt IT people only installed the pdms but i dont knwo what they done, while installing the pdms. and another question is while installing the pdms administrator is required?
For installing no Admin is required but it would be handy to have someone aboard when you do. If the windows enviroment is protected you can set the PDMSWK folder to another drive where users do have full access. And they will also need a full access PDMSUSER folder. Installing is not the problem anymore setting it up so it works for your company is the main issue nowadays.
[QUOTE=dhandayadhapani.ramalinga;31351]ok thanks for your reply,
thanks in advance,
ram...
As yar_nl mentioned you don't need an admin to install it. Although it would help to have someone that is familiar with PDMS to install it and set it up in your company, as they know the little details, such as making your PDMSWK and PDMSUSER folders write-able. PDMS is very easy to deploy in my opinion, as you don't have to worry about 3rd party tool setup, like Oracle or SQL server, and the project set up is a nice GUI, unlike other tools.
