PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting Database Error
  • Replies 26 replies
  • Views 49 views
Database Error
dsfgdsfg
dsfgdsfg over 18 years ago
  • dsfgdsfg
    Hi there.
    When i try to create an ISO i get a Database Error 18 for one of my pipes.
    The problem is i don't know what Database Error 18 means, maybe someone can help out.
    Greets
  • HowD
    HowD over 18 years ago
    Reference this post:
    http://www.pdmsworld.com/forum/showthread.php?t=1109
    There is a zip file attached with error codes.
    http://www.pdmsworld.com/forum/attachment.php?attachmentid=358&d=1161673524
  • Craig Durr
    Craig Durr over 18 years ago
    Here is another list of other types of Errors
    show !!messagelist
  • dsfgdsfg
    Thanks alot.
  • Dave Simmons
    Dave Simmons over 18 years ago
    Can this (show !!messagelist) be extracted to a file?  I would be nice to have a printable document of these other errors.  We have the file provided by Tback which is awsome but the more we can have access to the better young users will be able to learn from these errors.
  • Craig Durr
    I do not know.
    Maybe Neil could answer this one?
  • Chuck Wester
    Chuck Wester over 18 years ago
    Is this the only pipe you get the error on?
    Have you run data consistency on the pipe to see if there are any errors?
    Have you checked the message file to determine if any errors are generated in the file?
    Post the results of what you find and maybe we can help.  I know this doesn't directly answer your question but this may lead to an answer.
  • dsfgdsfg
    Thanks that you want to assist repairing my pipes but its solved already :). Just wanted the Error Code explained and this list is nice.
  • HowD
    267960messagelist.zip
  • Chuck Wester
    Just curious............what did you do to fix the problem?
