PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting Plotting With Plotviewer
  • Replies 19 replies
  • Views 30 views
Garth Watkins
Garth Watkins over 18 years ago
  • Raymond Metselaar
    Raymond Metselaar over 17 years ago
    The use of a soft driver as you put is done when you plot the file to the printer. Now I do not have an example for it but maybe you can look at this thread. http://www.pdmsworld.com/forum/showthread.php?t=1465
  • Thomas Back
    Thomas Back over 17 years ago
    When you output a .plt file from PDMS you cannot specify a softdriver.
    The outputted .plt file can be sent to the plot.exe application in the same folder as plotviewer.exe, and this application can use softdrivers specified in the PLOTDRIVERS file.
    You find more in the plot.exe manual supplied with PDMS.
  • Nandkumar Thorat
    Nandkumar Thorat over 14 years ago
    I am using Pdms 11.6 SP5 similar to batch plotting of plt file. There is utiliy to print PDMS .plt file to .PDF. Command from draft is 'SYSCOM 'PLOTSERVPDF  C:\Gorgon\plotfiles\G1-TD-S-4100-GEN222801-S1.plt '
    but it create pdf in color format. can you explain me how to set it to black and white.
    plotsercpdf.exe if located at "C:\Program Files\Common Files\Aveva Shared\Plot"
    please help
    Regards
    Nandkumar
  • Stuartd
    Stuartd over 14 years ago
    Nankumar
    If you use the switch '-bw' in the command it switches to black and white. Note this is case-sensitive. Command is therefore:
    PLOTSERVPDF[COLOR="Red"] -bw [/COLOR]C:\Gorgon\plotfiles\G1-TD-S-4100-GEN222801-S1.plt
    Cheers
    SD
  • Dragan Grubac
    Dragan Grubac over 13 years ago
    Halo everybody,
    Sorry for resurrection but I have a problem with Plot Viewer. After plotting all lines get the same weight. Does anyone have a idea how am I going to solve this problem? And additionally, I MUST use the Plot Viewer to get the drawings on paper.
    Thanks
  • Craig Durr
    Craig Durr over 12 years ago
    Below works to create the *.plt in color
    I want it to create in black and white
    I try place -bw but cant get it right
    Any suggestions?
    PLOT $!LIST /$!NAME OVER
    SYSCOM 'C:\temp\PlotViewer.exe /p $!NAME'
  • Craig Durr
    I did find this in another file but every method I used doesnt work
    PLOT $!NAME PRINT 'MINL 0.3, COL BW, REDUCE, EXPAND'
  • Stuartd
    Stuartd over 12 years ago
    Not sure on this one but page 4:12 of the PLOT user guide suggests that your plot command might need to be:
    PLOT PDMS $!LIST /$!NAME OVER
  • Alfonso Garcia
    Alfonso Garcia over 11 years ago
    I know this is an old thread but I am also having issues plotting from plot viewer version 12.
    If I send a print to our Dell printer and choose 8 1/2 x 11 paper, the print fills the entire page.
    If I send a print to our Dell printer and choose 11 x 17 paper, the print is centered on the page and DOES NOT fill the entire page.
    Any suggestions?
